intake manifold
Old Sep 12, 2002 | 12:50 PM
rich88gta's Avatar
intake manifold
Ok I just finished doing some work on my stock base and I am getting ready to install everything. I am a little confused about the underside of my manifold base, however. There seem to be a few holes underneath the manifold on the coolent tank. Are these holes supposed to be pluged? If they are not....how does the coolent keep from draining into the distributor hole?
Old Sep 12, 2002 | 04:54 PM
rezinn's Avatar
Coolant tank? What? That sheet metal thing is a heat shield. The distributor hole does not connect directly to the lifter valley, either.
Old Sep 12, 2002 | 05:53 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
#1 - It's not a coolant tank, as the first guy said, it's a heat shield. And i wouldn't plug the holes, they let it drain. Otherwise, oil would seep in at the junction at the top and then fill it up.
#2 - What do you mean you worked on the base. Looks like you cleaned it really good. Now why not try porting it a bit?
Old Sep 13, 2002 | 07:28 PM
rich88gta's Avatar
This is what I mean by work
Old Sep 13, 2002 | 11:23 PM
BobMachus's Avatar
Looks great, please give us some posts about "after performance. I just got some AS&M runners I am going to put on a siamesed base if I ever finish the polishing.
Bob
Old Sep 13, 2002 | 11:26 PM
rich88gta's Avatar
Well, after all was put back together I noticed that the car pulls harder in 2nd and 3rd gear. The RPM range increased also. It pulls well all the way to 6000. I also put on a set of SLP runners.
Very effective mod for the price.
Old Sep 13, 2002 | 11:31 PM
BobMachus's Avatar
Do you have any before/after track times, or dyno runs?
Old Sep 13, 2002 | 11:49 PM
rich88gta's Avatar
I just finished putting everything back together. I also have to get some new tires put on, so it may be awile before I get it to the track and have it dynoed.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
