View Poll Results: what would u do
waste of money
50.00%
helluva deal
0%
i just orederd mine
0%
why 350? im buildin a 406
50.00%
Voters: 4. You may not vote on this poll
block kit special
Old Sep 17, 2002 | 02:45 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
block kit special
isaw this in my october issue of CHP...its a 350 block kit that includes..
4 bolt mains honed for moly rings
forged trw pistons
PAW heavy duty rods w/ chromoly rod bolts
custom ground crank on rod and main journals
double roller timing set
and ur choice of hydrualic or solid cam
this is for $1595
and the long block is everything above with
world products heads with 3 angle valve job (1.94/1.50)
hi performance springs
HD locks
chromoly pushrods
lifters
hi volume oil pump
long slot rockers
and a complete gasket set
this is for $2195
options are
10.1 compression (9.3 is included) $100
steel crank (is this forged?) $150
heads with 2.02 1.60 $110
guide plates $100
main stud kit (4 bolt mains) $59
head stud kit $125
how does this sound??....
im really thinking about this
let me know what u guys think...
later
rob
Old Sep 17, 2002 | 05:43 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Is that already assembled?
It's not a bad price. If you want to make some power, I'd stay away from those heads though.
Any decent local machine shop in your area should be able to put together the same package for about the same cash.
Old Sep 17, 2002 | 07:45 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
it comes unassembled...which isnt a problem..
and i forgot one of the options
377ci for $300
i was thinking about the short block with the head and main studs 10.1 forged crank (which i have for my 305 but ill have to get it reblanced) and slap ona good set of heads and a lt1 intake..
Old Sep 18, 2002 | 06:23 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
For $1995 you can get a NEW ZZ4 shortblock assembled from GM. $1595 for questionable quality parts & no assembly doesn't sound like a good deal to me.
Old Sep 18, 2002 | 07:44 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
no ****?....i didnt knwo that...i only saw the complete motor for about 3 grand....can u get forged pistons with the zz4 short block?....im glad u told me this...
Old Sep 19, 2002 | 10:20 PM
rockind78's Avatar
The ZZ4 comes with hypereutectics. Those are good to around 400-450 hp. I wouldn't really consider them for forced induction though.
Old Sep 20, 2002 | 11:46 AM
Morley's Avatar
They will hold up fine with a supercharger/turbo, so long as you don't get crazy with the boost, I wouldn't go over 10psi.
Old Sep 20, 2002 | 12:35 PM
Ricktpi's Avatar
http://www.gmpartsdirect.com/ Search for part# 12561723
These guys sell it for $1886.00, I would figure shipping on top of that.
Old Sep 20, 2002 | 01:22 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Just my opinion, but you guys are confusing new with 'better', and that's not always the case.
If he wants to put a blower on the motor, you'd have to buy the zz4 shortblock and change pistons to some forged ones. The gm steel crank is overpriced for the strength it offers compared to the steel $200 scat or eagle cranks.
Just my $.02. You could put together a stonger motor for the same price or cheaper by buying the right used parts, block, crank, rods, etc. than the zz4 shortblock, and putting it together yourself or pay the machine shop $250 to assemble it.
It's your money.
RedLeader289
Jan 22, 2016 03:05 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
BBSDesigns
Aug 11, 2015 07:39 PM
