Keeping the 5.7 TPI stock (mostly)
Old Sep 18, 2002 | 09:56 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Sooo... if I were to get my hands on an F-Body with the L98 and didn't want to do any major internal mods but had this in mind:
1. Cold Air intake
2. Ported and Polished Plenum
3. Headers
4. Full catback exhaust
5. Nice ignition setup
Would I be being too optimisitic to hope for 13.8-14.0 quarter mile runs? I know these cars can do 14.5 bone stock so...
Old Sep 18, 2002 | 09:58 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
thats seems possible but put some slicks and maybe a 2400-3000 stall and youl be mid 13's
Old Sep 19, 2002 | 03:18 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I need to ask - what does an aftermarket stall actually do? Something for torque lockup or what?
Old Sep 19, 2002 | 04:00 AM
Z_Ghost's Avatar
Some drag radials will help out alot, but you should see low 14's easy.
I got my Z to run 14.4 when it was all stock on a day when it was about 100* out and the car had 80,000 miles on it.
Old Sep 19, 2002 | 08:19 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: Keeping the 5.7 TPI stock (mostly)
Originally posted by D Stroy H8
1. Cold Air intake
3. Headers
All looks nice, but with the the ignition setup I'd just get a MSD Coil, Wires and a fresh set of AC PLugs. Dont waste your money on Planinums or anythign fancy. Good Old AC's will run flawlesly. Also if the car has a few miles on it you may want to look into rebuilding the distributor. I didnt have any problems , but just a stuble every now and then. (car had 70,000 miles) I replaces the pickup coil and ignition modle and cleaned everythign up and it ran soooo smooth. I had a MSD Box on my car and it crapped out on me so I'm running a fresh ignition like mentioned abov with a whole slew of mods (heads cam intake) and the stock ignition runs beautiful
Old Sep 20, 2002 | 10:15 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Sounds good - platinums don't help at all huh? I thought to just get the bosch +2's cause they aint to expensive, or the AC Delco rapidfires, b/c regardless plugs dont cost much
Old Sep 21, 2002 | 12:00 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes. But start out with a lower mile G92 L98, (87-90 IROC-Z or 91-92 Z28) they can run low/real low 14's. That will make what you want to do easier. Do the ram air, air foil, K&N filters, headers, (1 5/8's will probably be fine for what you wanna do) plenum porting, complete 3" exhaust including converter, (maybe a cut-out) and advance the timing. The igniton stuff won't make that much of a difference and I agree on the AC Delco spark plugs. Post your results if you ever do that.
Old Sep 21, 2002 | 04:47 PM
jd13's Avatar
Depending on what year you get, those numbers will be accomplished quite easily imo. You get an early l98 it won't be as easy as getting a late one.
Check out my sig for times and mods. I've been told it could be is a 13.9-14.0 run. Never know though. GL.
Old Sep 21, 2002 | 11:21 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Cool yeah I want a later L98 87 and up - thtas what I had in my mind. Soooo the stall converter question again. Whats it do functionally to make the car quicker?
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
squiggy2
Aug 9, 2015 09:30 PM
