Arizona speed TB's
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
Arizona speed TB's
A friend is selling his 58mm. I never heard of this brand before, is it any good? http://www.azspeed.com/
58mm too big? I'm going to port out the plemun to match up with the bigger TB and add a adjustable fuel pressure regulator.
Do you have any other mods to the motor. remember than too much air means s l o w air at low RPM's.....which is where the engine on a street car spends most of it's time.
Opps not there.....
Mods are Hypertech chip MSD stuffs, K&N filters, Flowmaster stock replacement mufflers with the dual cats removed and a BBK 52mm TB. Also got a 3" Y pipe yet got to be installed. Best ET's are 14.8@102MPH with a 2.4 60ft.
Originally posted by Bort62
Wooo Take it easy on the fun pedal With those launches
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Ya save your money and buy desktop dyno... in the dyno on a 390 hp tpi motor I was messing with increasing flow from 780 (stock tb) to a 1100 (~58mm tb) is under 5 hp difference. And the difference between a zz4 cam and a comp cam xtrem 270H is like 25+ hp... so buy desktop dyno check out some cam numbers and get a good cam to get as much of an hp increase as full exhaust. That is my 2 cents
sorry my bad :).....
Should had checked my time slips, I only raced the car twice first was 14.8@94 and the second another time was 14.8@96. Sorry 102 did sound kinda fishy? I appoligize
Benny,
I will be at the raceway this Saturday for the shoot-out in my GN.
. Benny,
Elephantismo
Feb 13, 2019 12:51 AM
