cant get starter in
Old Feb 17, 2003 | 08:41 PM
camzcruizer's Avatar
cant get starter in
hey im putting in a new starter and i cant get it up into the right position because it such a tight squeeze by the exhaust pipe anyone have this problem before i really dont want to take out the exhaust pipe
Old Feb 17, 2003 | 09:35 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Your probably going to need to remove your Y pipe, theres really no way around it. You could try losening the bolts and see if it will move out of your way enough though.
Old Feb 17, 2003 | 10:37 PM
yeah thats definetly what i didnt want to hear my y pipe is welded to my cats and all the bolts are like heated so this should be interesting its definetly going to involve some beer hahaa
Old Feb 17, 2003 | 11:15 PM
SillyWabbit's Avatar
Car: '91 Formula
For the stock size starter, I found that just unbolting the connection at the exhaust manifold on both sides of the engine allowed the y-pipe assembly to drop down enough to be able to move the starter around in there. Although it added yet another step to the process, I didn't find that this was all too difficult to do, and made the process much much easier.
Old Feb 17, 2003 | 11:47 PM
ill try that thanks
Old Feb 18, 2003 | 07:15 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Sorry if im too late, but i did both starters in my 2 cars and the same issue came up. No matter whay i did, i couldnt get it out. I ended up disconnecting the solenoid to get it out and doing the exact opposite to get it in. The dual cat cars are the worst. And sometomes the bolts on the pipes are way to rusted to un-do.
Old Feb 18, 2003 | 04:06 PM
okay i got it up by removing the solenoid but now i dont knoww which wires go where? i have 3 that look like they go on the the big thread and then one little one for the little thread but theres two smaller threads and i only have one small wire, this make any sense?
Old Feb 21, 2003 | 04:11 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
The smaller thread goes on the small post on the side facing the block. Once you hook up that small wire, its easy to figure where the rest go.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
