How did the cams differ betwen different L98 years?
Old Mar 26, 2003 | 05:55 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I've got an opportunity sometime in the future to get the cam out of a 91 L98. Is this cam better than my 87 L98 cam? what kind of gains would it give me? Would it be worth the trouble to swap?
thanks
Old Mar 26, 2003 | 06:10 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There are 2 L98 cams. The MAF cam and the SD cam. The MAF cam (the one you have now) is actually a little bigger than the later one, and also has a slightly wider LSA.
The specs are so close, and since the MAF cam is slightly bigger anyway, no you wouldn't wanty to swap.
Old Mar 26, 2003 | 08:04 PM
Car: 1987 GTA
Transmission: 4L60e
thanks.
Old Mar 27, 2003 | 09:33 AM
Car: 1987 GTA
Transmission: 4L60e
hold on a sec. I have an 87. Weren't those cams smaller than the 88-89 cam?
Old Mar 27, 2003 | 02:53 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Yeah, check the tech data base for cam breakdowns.
yours is 202/207 @.050, .404/.415
90-92 is 202/207 @.050, .413/.428
Barely any different, not sure it would be worth it, just add some 1.6 rockers and you're well past the 90-92s lift...
Old Mar 27, 2003 | 03:42 PM
Ed Maher's Avatar
Car: 04 GTO
Thats what i get for going off memory. Just did some quick searches and it seems everything says the 87s had a smaller cam than the 88-89. What's weird though is the specs for the 87 cam look exactly like the flat tappet 'vette cam that the 85 TPI and L69 cars had. So it's possible that it's bad data.
Either way, not really worth swapping.
Old Mar 28, 2003 | 12:23 AM
Car: 1987 GTA
Transmission: 4L60e
ok, that makes sense. Guess I'll just wait for an LPE cam then
Old Mar 28, 2003 | 07:38 AM
The Anvil's Avatar
Car: 1989 GTA
Engine: L98 350, dual cats
Transmission: 700R-4
Correct.
The 1988-89 L98's had the 'big cam':
PN#10066049
207/213 .413"/.430" 117 lobe sep angle
TheExaminer
Aug 19, 2015 10:07 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
anesthes
Aug 8, 2015 09:37 PM
