LT-1 crank in L-98 TPI 350????
Old Apr 3, 2003 | 12:11 PM
Greenmonster138's Avatar
Will a Lt1 crank work with a tpi motor? I know that the lt1 cranks are stronger, but not sure if they will work with the L-98 350? If not what are the reasons for them not working?
Old Apr 3, 2003 | 12:17 PM
TwistedIROC's Avatar
Yes, it will fit.
Kyle
Old Apr 3, 2003 | 12:24 PM
Is there any reason not to use the lt1 crank? Or do you think it would be a wise thing to do?
Old Apr 3, 2003 | 01:21 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
dang
i'd say they balance differently...... but i would go with a factory or a new scat 9000 series..... either will handle more than probably the block would......
think about it.. whens the last time you ever heard of a l98 crank breaking?
Old Apr 3, 2003 | 01:22 PM
Mark W. Winning's Avatar
Research this a bit more before doing it. I seem to remember that the LT1 crank is built more like the 305 crank. Its a lighter weight setup. I think the question was posted the other way around though, about using a 350 crank in an LT1.
Old Apr 3, 2003 | 01:36 PM
Does anyone know someone selling a L-98 crank???
I have the LT-1 crank just sitting around and am building a L-98 to bolt up to a t-56. I am just starting with a bare block, thought it wouldn't be a bad idea to use it since I have a LT-1 crank sitting around.
Old Apr 3, 2003 | 09:25 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
if you have the crank just use it dood... i have one that i am gonna put in my 355 here this summer... only difference is that the LT1 crank only has a half woodruf key while the regular SBC cranks have a full key... to make the LT1 crank work just tap out the one in there now and install a normal full key...
and yes the L98 350 crank is balanced differntly than the LT1 crank... w/ the LT1 engine they used lighter pistons and rods so they balanced the crank differently... but it will work... i am gonna install mine w/ the LT1 crank and LT1 PM rods... and a light weight piston to try and help the balancing process...
Old Apr 5, 2003 | 09:27 AM
Vader's Avatar
If you use the factory PM rods or 305 rods, you'll have an easier time balancing the rotating assembly.
Caspar
Jun 19, 2016 11:19 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
cRoe4
Aug 7, 2015 08:46 PM
