Chevy High Performance ***Stealth Ram install***
Old Apr 16, 2003 | 10:57 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
in the new Chevy High performance mag, the in stalled a HSR on a 350 camero that was running 14.45s and it dropped to 14.1 and with a junk Hypercrap it pulled a 14.flat....anyone else see this if so it looks like we have published prof of its power adding abillity.... just what till, us ECM hacks can get a hold of its power... what do you guy's think about this artical,
i myself didn't get to read the whole thing, one of my friends had a copy, but i didn't see anything worth buying in it.....
Old Apr 16, 2003 | 11:27 PM
91-ZZ4-Z28's Avatar
Re: Chevy High Performance ***Stealth Ram install***
Originally posted by fun Pain
camero
CAMARO:lala:
Old Apr 16, 2003 | 11:32 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
I found the parts list they gave useful at least for my future swap. Do you really have to cap off your heater control valve? They did that in the article and it's enough to make me think twice about getting one.
Old Apr 16, 2003 | 11:42 PM
esams's Avatar
Letcha know boyz. I'll nail it on the dyno as good as the stock chip can do with fuel pressure and timing. All I care about is the power from 3600 to 5200 rpm since the converter plays in that range. I don't care if the Stealth gains 1 peak hp over the TPI. All I care about is that it holds the peak reasonably until 5200 rpm.
Old Apr 17, 2003 | 12:30 AM
Car: 1992 Z28
I don't care if the Stealth gains 1hp
LOL i dont care if it gives 1 more either, but i do care if it gives me 50-60 <---sarcasm
:lala:
Old Apr 17, 2003 | 08:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Why? The only thing that does is prevent coolant from going through your heater core when the heater is in the "off" position. Put your control to the "heat" position, with the temp and fan all the way down and see if you can live with it. I doubt you'll even feel a difference. My GTA and my IROC both have the heater valve bypassed and there are absolutely no ill results to report. My AC still keeps me plenty cold in the GTA all summer.
But... if you really wanted to keep it, I don't see why the stealth ram will prevent that from happening.
Old Apr 17, 2003 | 08:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
I just finsihed my HSR install and I didnt have to bypass ANYTHING. If Im thinking of the right things here, the heater control valve is the black plastic thingy that has 3 heater hoses and a vacumm line going into right? Well if it is, I relocated mine yeasterday. I ran a new longer line off the intake and put the valve down on the frame rail just beside the #2 header pipe. I also put a longer line off the heater core. Now I can see the passenger valve cover.
Old Apr 19, 2003 | 02:23 AM
BadSS's Avatar
Hmmm,,, either they swapped the pictures around in the article, or he has the fuel feed (inlet) running to the regulator.
Old May 7, 2004 | 07:15 PM
max93's Avatar
do you have any pics of this?
Old May 7, 2004 | 09:53 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
click the green banner.
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Feb 21, 2016 01:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
scottmoyer
Sep 5, 2015 09:33 AM
