For those of you running Accel 8.8mm wires...
Old Apr 25, 2003 | 07:46 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
.....the custom fit ones.....I'd just like to know how much luck you've had with them. After replacing 3 wires that were cracked and arching on numerous occaisions over the last few months....I went with the 8.8's. So whats the concensus on quality, durability, longetivity and overall satisfaction with these wires? Feedback would be greatly appreciated. I plan on getting the supercoil if my car doesnt give me any c**p again anytime soon. The plugs i'm using currently are regular bosch platinums. Any suggestions or comments? Thankx.
Old Apr 25, 2003 | 08:53 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I just bought a set of the Accel 8.8 MM plug wires with 90 degree boots....I'm about to get my headers installed..and these were recommended...I know a few people with them...they've never had any problems....
Attached Thumbnails For those of you running Accel 8.8mm wires...-enginebay.jpg
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I have been running accel 8.8's for two years and no problems yet.:rockon:
Old Apr 25, 2003 | 10:08 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Awesome...if they hold their own, then this was the best $50 bucks I've spent on this car so far. Thanks guys. :lala: :lala:
Old Apr 27, 2003 | 01:41 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I know what you mean about non-stop mechanical failures and problems. I am only now getting that under control. I've had the car for 8 months and I have just started modding it as of late.
Old Apr 27, 2003 | 08:09 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Exactly....i mean, it seems like everytime i want to do a modification, something just HAS to go bad...everything you see listed in my second list that I was going to do....i had all those things sitting in boxes in my living room. Everything was ready to be done at once. But then, my MAFS, trans govenor gear, 02 sensor, relays, and front end decide that they all want to go on a permanent vacation together. Definetly not something that helps my cause. Yea, its 17 years old.....things will go.....I'm just tired of it nickel and diming me. Hopefully, this will be it with the "FIXES" for a while...
Old Apr 28, 2003 | 09:36 AM
sillyiroc's Avatar
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
i have been using the 8.8 for about a year and the only problem i have had was when i installed my headers i couldnt use some of the strait ends i need all 90deg plug ends.
Old Apr 28, 2003 | 10:46 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i have 90* boots tucked under my longtubes
they sat all winter (actually they sat for exactly one year)
their now running great, no cracks, no arcing, no misses
Old Apr 28, 2003 | 11:05 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Good to hear. You really cant buy cheap parts for things like this. I learned that lesson fast. I think instead of modding my TA, i think its time I start doing mods to the C5. Although the mods for the TA are relatively cheap....300 total. The exhaust for the C5 i want is a borla stinger system, and it goes for $700...those are just the mufflers. I'll add Random Tech cats to the car as well, another $400 at least. Then intake, another $250-$400 depending on brand. So maybe i'll do the TA mods slowly.....IF nothing else goes wrong.
Old Jul 31, 2003 | 02:49 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
sorry to raise a topic from the dead, but what part # did you guys go with on the accel 8.8mm universal set? i cant seem to find the definite right thing, and i dont want to get the wrong thing again
Old Jul 31, 2003 | 03:10 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Accel Part # 8870 for the Custom Fit 8.8mm wires....hope this helps.
Old Jul 31, 2003 | 03:11 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Oh, you wanted the universal set? Sorry....I dont know that part #....
Old Jul 31, 2003 | 10:11 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have Accel 8.8 mm in my Camaro. When installing the new heads we accidently burned one of the accells and exposed the fiberglass braid. We tested our stupid idea of seeing if it would still send a spark through the wire. Sure enough it did, and still had almost 0 degrees of resistance (with the huge burn!), but we still replaced it. I have almost a whole Accel ignition system and I like it.
Old Aug 1, 2003 | 12:25 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Ive got an Accel control module, coil, cap, rotor, wires and plugs. I went through two sets of 8mms, then finally dished out the dough for 8.8s. Ive got uncoated headers and havent had a problem for the 2 1/2 years theyve been on.
Old Aug 1, 2003 | 01:07 PM
91blackgta's Avatar
Same here. I think most people have tried the 8mm and weren't satisfied. So The 8.8mm wires were the next try and the work great. I would recommend them. The custom set, not the universal.
Old Aug 5, 2003 | 06:17 PM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
P/N 8021 for universal 90 Accel 8.8. Had mine on for 4 years now. Still perfect condition.Running coated Hooker shorties also. Clears the headers well.
Old Aug 5, 2003 | 10:37 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Im running Accel 8.8s with my HSR. I must say it is a very tight fit back there with the huge boots. This may be due to abuse(twist, turn, pull, push them outta my way for several rocker installs among other things), but they seem to arch on anything around them. They are also two years old which may contribute.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
marcusaw
Aug 10, 2015 08:13 AM
