Accel Superram install???
Old May 31, 2003 | 08:01 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
All the stock equipment will just bolt on right? Fuel rail, injectors, egr, distributor..etc?? Thanks.
Old May 31, 2003 | 11:57 AM
jcsws6's Avatar
Yep
Old May 31, 2003 | 12:23 PM
MdFormula350's Avatar
i want a super ram anyone want to trade for a nice tpi setup j/k
the egr is the big factor in me maybe going with the super ram then going stealth ram or miniram.
Old May 31, 2003 | 01:23 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
If you buy a used one try to get the throttle bracket that comes with the Superram. The stock one will bolt to the superram but it puts the TV cable in a slight bind with the underside of the plenum. You can still use the stock one though.
Old May 31, 2003 | 02:09 PM
speed88's Avatar
Engine: 383
Thanks MikeH, I'm buying new so it shouldn't be an issue.
Old May 31, 2003 | 02:14 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You're gonna also have to delete your cold start injector. I think you can buy a CSI plug kit separately from Accel, I don't think the Superram kit comes with it.
Old May 31, 2003 | 02:16 PM
speed88's Avatar
Engine: 383
Why am I gonna have to delete that??
Old May 31, 2003 | 02:26 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
I've still got the cold start injector on my SR.
Old May 31, 2003 | 03:10 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Sorry, let me rephrase that. You don't need to delete it, you can just unplug it and leave it there, since there is no provision for the CSI on the left side runner. HTHs
Old May 31, 2003 | 06:01 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Hmm, I didn't know that. That explains why I've had trouble adjusting my TV cable. Can the bracket be purchased separately?
Old May 31, 2003 | 07:11 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Sorry I dont know....You could try Accel/mrgasket,summit,jegs,or Lingenfelter they would be able to tell you.
Old May 31, 2003 | 10:46 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Yeah, but it the SR runners aren't cast with the cold start hole in them. I had to modify that one so I could use the cold start injector before I got the Ed Wright chip with it deleted.
Guess it looks that good eh?!
Old Jun 2, 2003 | 01:07 PM
Car: Damn
Engine: This
Speed88, this is what I did,
Old Jun 3, 2003 | 03:51 AM
85TPI400's Avatar
'87FAKE-IROC-Z
Looks like a great idea. When you made that modification to your SR did you have to totally bend and reshape the CSI fuel line to clear the chunky runners? I remember when I installed a set of the Accel large tube runners on one of my cars that they were pretty big and had to reshape it a little bit.
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
marcusaw
Aug 10, 2015 08:13 AM
