Dead lined!!!
Old Jul 22, 2003 | 01:48 AM
Anthology83's Avatar
Dead lined!!!
ok first off this is my cousins name so disreguard the car info
i have an 86 trans am with a 305 fuel injected tpi automatic
it has new plugs...cap...rotor...coil for the ignition system
today i was driving around town and it started to bog down when i gave it gas...so i did it a few more times and it kept doing it...so i gave it a lil' more gas and it backfire...so i pulled into the post office and let it sit for like 5 minutes....then went to drive home ( only about a mile) and there is a hill....and upon climbing it to get out of the drive i stalled and it wouldn't start...so i let it roll down...let it sit for about a minute it and it started up...rough.....and i babied it on the way home....got in the drive way pulled it into the garage....and now it won't start at all...won't even act like it wants to...so i called up my 2nd cousin who is an expert mechanic and owns a shop and he told me to check plugs...intake housing to filter....fuel filter...make sure the rotor didn't come loose...make sure there was no moisure in the cap...and he gave me a procedure to check and see if it jumped timing....everything was nice..so i put a new coil in at that point for the hell of it...and it just rolls over...
give me all you guys got....i'm lost....and unhappy
Old Jul 22, 2003 | 02:06 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
$20 says its your fuel pump. Ask me how I know! Get a fuel pressure guage and stick it on the shcraeder valve on the back side of the passenger fuel rail. If you are seeing less than 40 psi of fuel pressure when you try to crank it over, your fuel pump bought the farm. It should read nearly 50 psi. When mine went, it read about 20 psi.
Old Jul 22, 2003 | 03:05 PM
ok...i'll do that...but that means i have to go buy a fuel pressure tester....so in the mean time since that will be later today or tomorrow....i'd love more ideas
( the fuel pump is what i'm worried about..i don't want to have to take the tank out...i've heard of what trouble that is!! so through more ideas out please)
Old Jul 22, 2003 | 05:12 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Fuel filter maybe. Check that out. Wouldn't be bad just to change it anyways. Especially if it hasnt been done in a while.
Matt
Old Jul 22, 2003 | 09:31 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Borrow your expert mechanic cousin's fuel pressure test guage.
Also the fuel pump is not all that hard to change just time consuming, very time consuming. If you can, ask to use a rack at your expert mechanic cousin's shop. That makes the job much easier.
Old Jul 22, 2003 | 10:08 PM
k....so i bought the pressure tester...and its getting about 47 psi....so its not the pump....so i checked my spark and it was getting no spark on one plug so i tested another and its getting no spark...so i tore into the distributor again and took the module out and i'm on my way to go get it tested
keep the suggestions comming
thanks!
Old Jul 23, 2003 | 12:08 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
thanks!
Sounds like you found the problem!
If you still want suggestions then I recommend you check your tire pressure
Old Jul 23, 2003 | 02:09 AM
yeah.....module failed the test bought a new one and installed it...and its back up and running again
thanks for your help
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Johnoooooo
Sep 22, 2015 08:55 AM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
andy74
Sep 3, 2015 08:41 AM
