350 TPI Stock 1/4mile runs ?
Old Sep 6, 2003 | 02:47 PM
Mprt_Klr1988's Avatar
I have an 88' GTA with a 350 TPI and nothing done to it at all..completely stock...I have heard many stories on what it would run out of the box...
but I want to hear from people that have actually ran they're stock 3rd gen with this engine and W-S6 suspension.
So help me out....how did yours run ? What times should I expect next weekend when I take it out ?
Old Sep 6, 2003 | 03:31 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
My timeslip looks like this:
It was 68 degrees
Humidity was 61%
Barometric Pressure was 30.45
Skies were overcast.
60' 2.023
330' 5.833
660' 9.060
660'MPH 75.620
1000' 11.875
1320' 14.255
1320'MPH 94.730
Old Sep 6, 2003 | 05:54 PM
smithtc's Avatar
Should run at least low 15s in the low 90s mph. A few tricks like air in front tires, getting traction, etc. should net you some high 14s...and mid 14s in some cases if the car is in good tune. The GTA cars are heavier than the other models.
Old Sep 6, 2003 | 11:58 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
look at your RPO codes for G92 to see what gears you have..that will dictate weather your a 14.8 or 14.4
i do agree that the GTA's are the heavyweights, however, ive ran a 14.1 with my lightly modded LB9 G92...
Old Sep 7, 2003 | 01:15 AM
I have Stock 3.27's in the rear.
Old Sep 7, 2003 | 08:16 AM
smithtc's Avatar
As far as I'm aware, I've never heard of a G92 GTA unless it is a 91 or 92 model.
Wouldn't the LB9 G92 be a 5-speed?? The 5 speed 305 formula model cars make the best times when driven correctly to my knowledge.
www.gtasourcepage.com
Old Sep 7, 2003 | 08:06 PM
89Formula350WS6's Avatar
My stock time is in signature below.
Old Sep 10, 2003 | 12:10 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
my first time to the track i netted a 14.3 bone stock, only mod was the cutout actually. after the cat. these cars are capable of way better than mid 14's stock with proper tuning and maintenance.
Will
Old Sep 10, 2003 | 06:42 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
with just a few bolt ons, i ran 14.4 on an 80-85* day.
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
st.evel07
Aug 13, 2015 06:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
