Question about Ram Air
Old Sep 28, 2003 | 07:29 PM
3gc's Avatar
3gc
Car: Z28
I am about to make ram air for my car following the tech article on this site for TPI engines. I bought the 8" felxible a/c ducting and the zip ties today. The ducting gets ziptied over the grill openings correct? If so what do i do with the metal bumper that's in the way?
Old Sep 30, 2003 | 10:58 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
this !
Old Sep 30, 2003 | 11:00 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
and this!
Old Sep 30, 2003 | 12:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I would recommend a grill of some sort though... I sucked a bird up in my Ram Air scoop when I had mine hooked up luckly it broke the metal heat duct flex tubing before it hit the air filter :-)
Old Sep 30, 2003 | 06:28 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
ROFLMAO are you serious?!!?!?!?!
jesus christ! immagine sucking a bird into your engine....take it to the mechanic....just picture the phone call....'uhh..sir...theres a bird in your intake....' lololololololololololololollollolololololololololololololololololololololollololololoolololoilolololololloollo
Old Sep 30, 2003 | 06:39 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
lol, my ram air made my car stall at highway speeds when i glided, like at the track after hitin the traps id put it in netrual and itd die, go to take an exit and glide itd stall, took out the ram air boxs no more problem, my car is a 5spd tho.
Old Oct 1, 2003 | 01:17 PM
Engine: 383 SBC
I bought a March Performance Pulleys Mustang scoop for my firebird. Since there's no other way to really rig up a ram air on a stock firebird, wish I could just do the metal vents like a camaro.
Anyways I eventually took it off after that episode. I then started to use it as a transmission ram air cooler.... I mounted it on driverside so it would suck extra air up into dam area. A evil parking lot removed that from the car... which I left there cause I didn't know. But my GF managed to pick it up and bring it back to me... I haven't put it back on yet.
Old Oct 1, 2003 | 02:19 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
A simple change to the chip's DFCO (Deceleration Fuel Cut Off) settings will stop that problem, AT or MT cars both.
Old Oct 1, 2003 | 03:30 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
LOL, see, Camaro's do eat bird's !!
Nah, but I have a unique screen planned for my grill. Maybe this weekend, I'll have pics.
Old Oct 1, 2003 | 03:45 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Re: Question about Ram Air
The metal bumper is in the way. While I custom made my ducts, the problem is the same. My approach was to use baffles to direct the air over that bumper support.
In the attached photo you'll notice an aluminum baffle near the bottom of the duct. This tucks underneath the Z-28 grill when it is installed to smooth out the air flow (this is a very simple install- use a rivet gun). I also have one on top that transitions from the top of the bumper support to the plastic nose cover.
Incidently, I took care of the bird problem by using 0.33 sq. in. stainless mesh to protect the opening. This system is fresh proto-type (literally just finished installing it last nite) material.
After painting it black (I'm not a fan of the brite duct work), I will be posting on the entire project.
Best of luck with your project-
S-D
I also wanted to add- I cut out the thin strip of plastic covering the metal bumper support. It was just getting in the way.
Attached Thumbnails Question about Ram Air-camaro-duct-installed-grill
Old Oct 2, 2003 | 12:31 PM
Car: 1991 RS
Black Ducting
I painted the bumper support baffles and ducts (inside only) black prior to re-installation. I like the black better than the original- too brite in my book.
Let us know how yours turns out 3gc!
S-D
Attached Thumbnails Question about Ram Air-camaro-duct-grill-finished
Old Oct 4, 2003 | 02:32 AM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
Bad91Z, what are you using for ducting?
Old Oct 4, 2003 | 12:55 PM
NEOMASTERZ28's Avatar
Car: 85 z28
i was thinkning toabout doing it to my 85 z but....what about water entering the motor ???
Old Oct 4, 2003 | 02:04 PM
vwdave's Avatar
Old Oct 7, 2003 | 03:13 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Neonmaster,i have used ram(with k/n filters) air 3 years at my -85 z.Only direct ducting,without baffles.Driven at heavy rain,no problems.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
