superram/afrs/stock cam
Old Dec 4, 2003 | 04:43 PM
gta on juice's Avatar
a friend of mine has an engine sittin around wich was an corvette l98.now it has afr 190s,superram and the stock l98 cam.he had a more agressive cam in it,but he claims it was to wild for street use(lumpy idle,no low end power...).he has not dynoed it.we both wonder how much power this combo makes.and at what rpm it falls on its face.id say 350hp at 4500,he claims 400 at 5200(both at the flywheel).what do you guys think?what would it run in the quarter in an f-body?
Old Dec 4, 2003 | 04:54 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
he is deff. leaving alot of power on the table by puting a stock cam back in it.
why degrade... pick a nice mild cam and Tune for the application.
Old Dec 4, 2003 | 05:35 PM
what would be the diff in hp lets say if he installs an lpe 211cam?
Old Dec 4, 2003 | 06:14 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
you mean a 219/219.
Im sure that cam would wak eit up a TON.
I cant predict any #'s but it woul ddeff. be a diff. over a stock peanut cam.
Old Dec 5, 2003 | 04:18 AM
83 Crossfire TA's Avatar
Re: superram/afrs/stock cam
Cams need to be matched to the parts that are installed in/on the engine.
where does it fall on it's face… drive it and find out. The only way you'll know for sure what it runs is if you run it at the track and find out.
WRT to what it could run? In theory it could be in the 11's. In practice, the way most 3rd gens end up you'll be lucky if you see 13's. FWIW, I've run 13.5's in a formula with a stock L98 with a cold air intake and cat back, pretty much stock otherwise.
Old Dec 5, 2003 | 09:16 AM
when he built the engine years ago,he talked to lingenfelter personally and he said only for steet use the stock cam with 1.6ratio rockers is just about right.and yes it was the 219/219cam.to unstreetable for my friend,hes got like 10mpg with that cam,he claims.that definately to low for an daily driver.but ok thats my firends opinion.maybe i will get this engine for my car and i def. wont go with the stock cam.but i dont know what cam to pick.what cam can i pick with the stock computer?i want a cam with good low end power right of stall speed(2000),and with some decent top end.i dont go to the strip,only steet use.internals are stock l98 with 10k miles,would that engine hold together with lets say a 100shot juice?thanks for opinions.
Old Dec 5, 2003 | 09:21 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Use the 219/219 cam. Just make sure you tune your prom for all of the changes!! Your buddy must have been using the stock chip
Old Dec 5, 2003 | 09:27 AM
yeah man he used the stock chip.is it that much a difference with a mild cam?it would surge,die at idle and so on.cus we dont live in the us,who makes good chips for such combos?i mean without having the car there?
Old Dec 5, 2003 | 09:40 AM
Car: 91Z
Wow, no wonder the car ran like crap! You can get a mail order chip, whitch will be your best bet(if you can't do it yourself. DO NOT go with TPIS for a prom!! You could try fast chip(ed wright I think it is) or, LPE recommends FAST PROM because they say fast prom know there cams well.
Old Dec 5, 2003 | 10:18 AM
Guido's Avatar
Car: 2000 Trans Am
Im moving this to the TPI forum
Old Dec 5, 2003 | 11:26 AM
what do you think,will the 211/219cam have a better low end than the 219/219.the 219/219 seems a liitle big to me.or is an lpe camshaft a must for the superram,are the no other good cams avaiable?wich would you prefer with afr190 and the superram for a daily driven car?
Old Dec 5, 2003 | 12:53 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Hmm, I have AFR 190's, SR and LPE 219 and think it's extremely mild. Easily a daily driver combo. I recommend he put the 219 back in and get some tuning. I had my stock PROM in for a little while and it ran rough, would stall. I haven't tuned mine yet, but I burnt a PROM w/ the ARAP.bin on it with a couple changes to fit my motor, and it drives well and makes decent power.
Old Dec 5, 2003 | 01:57 PM
he has an 219/219cam layin around.we will either put the engine in his camaro or my gta and then see how it performs.he claims when it was in his car it was exactly what he wanted,with stock cam/1.6rrs.i think with the 219cam its possible to get 400hp/tq out of it,that would be the goal.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
