flat tappet or roller cam on 305 tpi?
what does eveyone prefer. a roller or flat tappet cam on a 305. i'm building a good street car not a drag car but would like the best setup i can get. the heads will be ported or aftermarkets. i see alot of people putting in the zz4 cam. does it have good street manners. i can get the slp 51000 for cheap. or are there better than these to for my setup.
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Roller, reason being, less friction, no break in time, faster lobe ramps.
One thing in consideration, doe the 305 block have provisions for a roller cam and such. If not you gotta get retrofit roller lifters, and cam button, which i would say wouldnt be very cost effiecient on a 305.
If the 305 doesnt have provisions for a roller cam, i would use a flat tappet. Use the money you save from not using retrofit roller lifters, to go towards a roller 350.
Kevin
Kevin
Engine: 383, L69
For one, you cant use the stock roller lifter, they stick up to far in the lifter bore. You will need lifters like these or similar.
http://www.jegs.com/cgi-bin/ncommerc...30&prmenbr=361
Kevin
Kevin
Re: flat tappet or roller cam on 305 tpi?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Not sure what year your car is but pull the intake and know for sure. Either way roller is far superior to flat tappet in every way but price
thanks, i will look at the lifters, i have a 1990 camaro rs, with 305L. i am pretty sure they are flat. thanks again. i believe my goal is to pull the 305 out and replace it with a 350. i want to expand on hp with headers, cam, and 350 tbi. and i can not see any advantage in waisting my money on a 305 to do this. i need to find out if i order a 350 from for that car will be ok for what i want. i hope the 350 does not come with low compression pistons, because then i will have to replace them with better comp pistions.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your combo is a roller motor from the factory. However, i'd still check because a previous owner may have altered what's in there.
Car: check
Engine: check
Transmission: check
May not need to pull the intake to find out. Pull either valve cover then one easy to get to rocker and pushrod. Use a flashlight and peer down through the pushrod opening in the head.
Can you see a dogbone and the spider? If so, then roller, if not then flat tappet.
RBob.
RBob.
Thanks for noticing that, i didnt obviously. But good point.
