Question about My engine and HSR
Old Dec 14, 2003 | 08:53 AM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
I have the 300hp gm crate motor (before vortec heads).
http://www.salleechevrolet.com/Chevy...ckV8s/300.html
I'm putting an HSR and SLP 25lb injectors on my 87 T/A. I know the cam on the engine is mild but do you think this will work O.K. I have a buddy who's gonna help me burn a prom. I'm not sure if I can swing the $$ for a new cam and head work.
I'm hoping for a low 14 or high 13 sec 1/4 mile. My 84 ran a 14.06 with the same engine and a CCQjet. So I"m hoping for about the same 1/4 mile times.
The car also has 3.73's headers and exhaust.
Old Dec 14, 2003 | 01:47 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
So you have Vortec heads? If so, the HSR will not work.
Old Dec 14, 2003 | 03:00 PM
Car: 87 Trans Am
The heads on the my engine are casting #083 based off the cast iron L98 heads but with the 86 and older intake pattern. I already know it's gonna bolt up no problem since I have the HSR.
I'd just like to know if I can get away with just keeping the cam. Since my budget to swap the engine from my wrecked 84 to my 87 T/A is kinda small.
Here's the specs .435in/.460ex 212/222dur and 112 ls
Frank
Old Dec 15, 2003 | 06:14 AM
Car: 87 Trans Am
I guess I 'll find out soon enough how it's gonna work. If the power comes on like the LT1 in my moms 93 Formula I'll be happy.
Old Dec 15, 2003 | 06:19 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You should be OK, including the cam,,, the HSR will breath good at higher RPMs,, you will lose a bit of low end torque.
Your total performance should be very good.
Old Dec 16, 2003 | 08:42 AM
Car: 87 Trans Am
Thanks for the info. I hope my 3.73's will make for some of the low end torque loss.
Old Dec 16, 2003 | 10:16 AM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
I noticed zero drop in low end grunt with my stealthram.
Old Dec 16, 2003 | 12:56 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
And yes the HSR with work with CERTAIN years of the Vortec head. I know this because Holley said so, I just cant remeber what years exactly.
Old Dec 16, 2003 | 07:02 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you won't notice any loss of low end. the vortec heads they will fit are the pre 96 heads. the newer vortec heads with the 8 bolt intake will not fit in. there is a mesage board up at www.stealthram.com to help answer questions about it.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
