horspower 1/4 mile estimate
Old Dec 25, 2003 | 11:17 PM
blackroc68's Avatar
This is my setup.what do you think hp 1/4 mile et will be?383 9.8.1 compession ratio zz9 cam 1.6roller rockers,edelbrock e-tec 200heads scoggindickey vortec intake 24 pound injectors tpis afpr 323 posi rear
Old Dec 26, 2003 | 10:35 AM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
What transmission? What stall? What runners? Exhaust?
Old Dec 26, 2003 | 03:36 PM
blackroc68's Avatar
700r4 stock converter.hollow cat 3 inch flowmaster:lala: :lala:
Old Dec 26, 2003 | 04:26 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
maybe high 13's until you get a stall, and do some porting on your tpi. You need to get a stall in there, and the tpi is very restrictive until you port the runners, plenum, and yes, even the SD base. Your heads will flow pretty well, but you need to do a few things yet.
Old Dec 26, 2003 | 06:16 PM
blackroc68's Avatar
high13 s tock 305 tpi can do high 13s. i have a 383 with decent cam and heads
Old Dec 26, 2003 | 10:06 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A stock 305 TPI can NOT do high 13s, friend.
High 14's, maybe.
YOu may indeed have a decent cam & head combo... but the stock TPI will kill that right off. On the upside, when you do anything at all to free up CFM in the TPI you will gain tenths in leaps and bounds! In other words, all you need to do is pay a little attention to the intake now.
Old Dec 27, 2003 | 07:51 AM
blackroc68's Avatar
the intake is a scoggin dickey vortec tpi. i have seen it posted on here.my friend
Old Dec 27, 2003 | 01:03 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I think you are selling the combo short with high 13s if there's good traction and all things are in tune. I can see LOW 13s easy there. My stock L98 went 13.58 with 3.73s BFG d/r and a 2200 converter. It will make gobs of torque so traction is key for your setup.
Good luck,
Charlie
Old Dec 29, 2003 | 04:35 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
You can't really bench race here. A 350 is starved for air with an LTR setup. The Scoggin-Dickey base may flow a little better than stock, but the rest of his intake will not. If a 350 is starved, what do you think would happen with a 383? He will run a decent time when the rest of his intake is upgraded. But, if you want me to blow smoke, I can tell you that you have a 12 second ride, eventually.... just port your intake, runners, plenum, and get some headers, and then like another guy pointed out, your et will start to drop dramatically. Ultimately, everybody's car is different than the next guy's, and you can't just say that you'll run 12's or 13.0's, generically. As always, best of luck with all your hot rodding ventures.
Old Dec 29, 2003 | 04:45 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Fast cars are all about synergy. You can't just do something and expect the car to be a champ. You need to incorporate a system that will work together, and that's why you have to do the whole intake and not just one part of it.
Old Dec 29, 2003 | 05:31 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
thats so true
you car is only as good as the weakest link. which right now is your stall. and runners.
Old Jan 3, 2004 | 01:59 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Do you have headers yet?
Old Jan 3, 2004 | 03:13 PM
blackroc68's Avatar
I ported the exaust manifolds.(gasket matched)
Old Jan 5, 2004 | 09:48 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I like your setup and i hope the best for you. But what D Stroy and Gixxxer are trying to tell you is that no matter how healthy someone is if there trying to breath through a 1/2 inch pvc pipe while running a 100meter dash then there gona suffocate and there performance is gonna suck. If you give them a 1inch pvc there performance is gonna be better and so forth. Dont flame on the analogy! But like i said good luck and i envy you setup.
83 Crossfire TA
Jan 3, 2016 01:26 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
86CamaroDan
Sep 29, 2015 10:08 PM
skip91
Sep 24, 2015 03:29 PM
bellez77
Sep 5, 2015 08:39 PM
