cam for stock 350 tpi
Old Dec 28, 2003 | 10:08 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
I'm probably gonna pick up an L98 longblock. It's stock with rebuilt stock heads. I was wondering what the best cam would be to use with the stock valvetrain. I was thinking maybe the LT1 cam. Any suggestions are appreciated, thanks.
Old Dec 28, 2003 | 10:39 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Stock valvetrain? You can upgrade to a good spring and MUCH lighter retainers for under $100 so I wouldn't worry about that much. I am running comp 981 springs ($55 from Scoggin Dickey ) and some LT1 retainers ($13.50 on Ebay) Then you will be good for .500" lift.
Old Dec 29, 2003 | 03:39 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
The LT1 cam is practically the same as a L98 cam and not worth the effot. Post some more about your setup and I'm sure some folks will offer advice on a cam.
Old Dec 30, 2003 | 02:21 AM
Car: 92Z28
Transmission: A4
If you siamese the base a Hotcam with your stock rockers will work good. I'm running one now and really like it.
Old Dec 30, 2003 | 08:50 AM
Pat Hall's Avatar
I'm gonna run the ZZ4 cam with my L98. I've heard from other members that it will work good with the stock prom and is quite an improvement over the stock cam. You will have to upgrade the springs and check the valve retainer to guide clearance though since the exhaust lift is .510.
Old Dec 30, 2003 | 01:10 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
Well, I might get an engine without a cam, it's a stock L98. So I'd have to put one in anyways. I just want to get my car running first and money is an issue.
Old Dec 31, 2003 | 11:46 AM
Pat Hall's Avatar
Oh, so you're lacking a cam altogether. I thought you were wanting to upgrade from your stock cam. Hell, if you want a stock L98 cam, just post a wanted ad in the classifieds here. There's probably several guys that'd just make you pay the shipping on it and give you the cam for free.
Old Dec 31, 2003 | 04:15 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Don't get a stock L98 cam!! A camshaft is not expensive anyway - get a better one than stock and you'll thank yourself for the improved powerband
I would agree with the hotcam suggestion - but only if you are willing to get the base siamesed. If not, then I would call compcams and see what they have to say about a cam for a bone stock L98.
Old Jan 1, 2004 | 08:16 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Just get the zz4, there cheap and run well under tpi.
Old Jan 1, 2004 | 05:29 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
How about a regular LT4 cam? They seem to be cheap and plentiful. Other than that I guess the options are the hotcam, and ZZ4.
camaro71633
Sep 1, 2015 10:24 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
