OOPS!! Is this going to be a problem???
Old Jan 21, 2004 | 11:37 PM
edge433's Avatar
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
I was taking the top of the engine apart tonight and happened to put a ding in one of the front runner tubes. Can I just use something to push it back out from the inside? Or is it screwed? If so, whats the best place to get a new one. Its the driverside. Would now be the time to get siamesed runners? Will a small ripple in one runners make performance suffer? Thanks, Tim
Old Jan 21, 2004 | 11:47 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A small ding? It's fine, dude.
Old Jan 21, 2004 | 11:48 PM
edge433's Avatar
Its about an inch long and maybe a 1/4" deep, Still fine?
Old Jan 22, 2004 | 12:04 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i would not suggest trying to pry the dent back out as these tubes are very thin and may crack it wont hinder performance..
Old Jan 22, 2004 | 01:24 AM
edge433's Avatar
I used a piece of broom handle, it came out good. Its just a little wavy. Now that thats solved, whats the best way to clean the inside? I was figuring a bottle brush and solvent. Any suggestions? Thanks again, Tim
Old Jan 22, 2004 | 05:57 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Easy off oven cleaner.
Old Jan 22, 2004 | 08:59 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Stock runners are so restrictive anyway, you would hardly notice a performance change with a small ding...
Looks bad though if it very noticable...
Old Jan 22, 2004 | 04:42 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
ya, I just used a socket extension and tapped very lightly with a very small hammer, but now that I think about it a broom handled with very rounded top would probably be safer. If your polishing them sand them like normal and the ripples will go away. After buffing you'll never know they were there.
Old Jan 23, 2004 | 01:12 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
heh, mine are all banged up from whoever's car they came out of. tpi doesnt put up a fight to begin with, and while every little bit counts, a few dents wont hurt anything.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
