What is a good price for a TPI Intake setup off 92' Camaro??
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I know someone selling a complete TPI intake setup off a 92 Camaro with distributor and computer. No wiring harness. He wants around $500 bucks for it. The intake setup looks like brand new. Is this a good price or not?? If not what do you guys think it's worth??
Car: 91 Camaro RS
Engine: 305 TBI
I forgot to mention that it has K&N filter which won't be of any use with stock filter setup, polished fuel rails, polished thermostat housing, new gaskets, and a new fuel pump. Is 500 still asking too much??
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
This swap wont be cheap. You'll need a harness. New, they are 295 dollars. ECM from ebay $100. Distributor, new $100. Fuel pump new is about $100 (IN TANK GM). If runners have dings in them I would say $200-250 for the setup (runners,plenum,rails and intake). Buying the intake without prior examination is tricky because there tends to be some pitting in key areas (usually). I would go the stealthram way myself but if you really want the tpi setup I hope I helped a little. It will work fine on your 305. The tpi setups arent worth much anymore because of the popularity and price of a stealthram system (500 dollars complete). Also, my price quotes are estimates for the tpi stuff. Shop around.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
