gas leak?
Old Mar 1, 2004 | 12:23 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
gas leak?
So I had(ve) and issue in my 89 350 tpi where once the car got warm and then I turned it off, it would not start back up, it would just turn and turn but not fire, until at least an hour went by, in which it would start again. I was told it was most likely the control module or also possibly leaky fuel injectors. The thing now is that it appears to be leaking gas when it is running, not alot, but enough to make gas puddles if the ground is wet, (the snow is melting around here, so the ground is always wet.) Im just wondering if there is any possible way that if the injectors are leaking that somehow it is making it to the ground???? seems totally impossible to me, but im not sure where the gas is coming from, the bottom of the car is pretty clean so a busted line seems unlikely to me... i dunno, any help would be appreciated, also if im lacking details just tell me, ill post more. thanks guys.
Old Mar 4, 2004 | 11:28 PM
bandit454's Avatar
Check the flexable fuel lines where they screw into the fuel rail. oou will have to take them loose to look at the oring. These have a oring in them and if they leak there it will leak onto the ground without getting on the car if i is leaking. As far as the hard start without sitting sounds like a leaky injector, so you may have two problems. I dont see a leaking injector leaking enough that it would not get gas on top of intake if i was leaking that much, I feel you will fing the oring bad where it hooks up to fuel rail right under the throttle body. Hope this helps, have saw this problem numerous times.
Old Mar 5, 2004 | 07:25 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
cool man, i'll def. check on that, thanks for the help.
Old Apr 19, 2010 | 09:23 PM
swaterbenny's Avatar
Car: 1986 Pontiac Trans Am
Engine: 355 SBC
Axle/Gears: 2.77
Re: gas leak?
I'm having the same small puddle problem. What did you figure out? Thanks, Ben
Old Apr 19, 2010 | 09:56 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: gas leak?
Check out any joints in the fuel lines and the fuel rail for leaking. It should be easy to find. Then look into the hard starting.
Old Apr 19, 2010 | 10:13 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
Re: gas leak?
In my case, hard starting when warm was fixed by replacing the pickup coil in the dist. Could also be the ignition module. Try the pickup coil first.
Old Apr 19, 2010 | 10:17 PM
Engine: 355 SBC
Axle/Gears: 2.77
Re: gas leak?
Are there any sort of joints or connections over the area of the oil filter? I can't really tell and I am new to the v8 world. Thanks, Ben
Old Apr 20, 2010 | 10:23 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: gas leak?
Nothing runs by the oil filter but its not impossible for it to be dripping from the back of the fuel rail. The other possibility is the lines running under the body and up the drivers inner fender.
Old Apr 20, 2010 | 06:12 PM
Engine: 355 SBC
Axle/Gears: 2.77
Re: gas leak?
The back of the fuel rail? Is there a line going back there? From what I can tell there are 2 lines coming out the front, and the injectors don't appear to be leaking. Thanks, Ben
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
tgp1990
Sep 4, 2015 06:24 AM
