305 time slips
Old Mar 2, 2004 | 03:00 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
305 time slips
whats everyones 305s running and what are your mods.
mine is a stock 305 tpi. all ive done is ported the upper intake a little bit, accell 8.8 and a msd blaster coil. and a t5 swap.
and it ran a 15.4 at 92 but this is w/ 273's.
Old Mar 2, 2004 | 06:00 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
I won't run again til I get my posi installed...2.8 60' are craptacular. If it wasn't for them I'd be in the mid 9's in 1/8th mile...I ran a 9.98@74 with a 2.7 60'. Also, my 3rd gear syncro is almost totally dead to top it off.
YAY!
Old Mar 2, 2004 | 08:55 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
My best run so far was a 14.9@93mph. Thats in El Paso TX. Thats roughly a high 13 at sealevel. I have sun dried tires so that doesn't help. I just added fully ported heads and polished as well. I got rid of those 1/4 tall walls behind the TB while I was putting the heads on. I have a fully rebuilt 700R4 with 2300 miles and a stock converter. Headers, small Crane Cam, A/C delete, Air Foil and a Hypercrap chip I used from a friend to post that time. Without the chip I ran a 15.0. So I guess it sorta worked. If I can get the car running good with these heads I will run it again within the next week or 2 but for now it is running like crap. I know I didn't hook something up right. Gonna have to look into it.
Old Mar 2, 2004 | 08:56 PM
Oh and the engine is freshly rebuilt with about 6000 miles on it.
Old Mar 5, 2004 | 09:37 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
When my TBI camaro ran good I managed a 97mph in the 1/4 mile. I didn't have much. Torquer S/R heads, 3 inch flowmaster American Thunder exhaust, Accell ignition system, Open air element. 2.77 gears. Stock rebuilt T-5. stock everuthing else.
Old Mar 5, 2004 | 11:18 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
With only the free mods, I'm in the mid-high 14's (yippie) I really need to get to work on a new engine...
Old Mar 5, 2004 | 05:41 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
15.52 @ 88mph. I'm at 1700 ft above sea level. I have 2.73 gears in my car that aren't helping my times either.
Old Mar 5, 2004 | 05:43 PM
Andy 91GTA's Avatar
See mods in sig.
Old Mar 5, 2004 | 05:47 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
14.1 @ 99mph.
305 LG4 with 87 TPI heads and TPI setup. Cam, headers, 3" catback, etc...
Here is a vid 2 days after the swap was done,
http://www.transamws6.com/video/ZepherWS6.mpg
Best time I have on video was with the LG4 and Edelbrock carb/intake on the car, 15.04 @ 90mph
http://www.transamws6.com/video/Manny_1504.mpg
Old Mar 6, 2004 | 04:03 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I'll have some new ET's here in the next few weeks...I need to tune the engines chip and then take it and have it dyno'ed and then to the track and see what difference my new stuff has done.
my old was a wimpy times were....15.42 but that was with a nasty tune and my first time ever to a track...so it may have been better than that..
Im hoping with the way the car is now in my sig to be deep into the 14's or praying for high 13's that would be great!...Im sure that if I got a stall and new rear gears I would be in the 13's...
whatcha think?
Old Mar 10, 2004 | 03:15 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
See sig
Old Mar 10, 2004 | 04:24 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
9.48 1/8 @ 74 mph w/ 2.059 60'. Should be around a 14.7 in the 1/4.
AFPR, Hooker cat-back, 3.42s. Free mods...
Old Mar 11, 2004 | 08:56 AM
JayBernard's Avatar
Car: 1987 Z28 A4
My times
My best to-date is 14.78 @ 91 mph, 2.04 60' :lala:
all i have done is hedman shorties, cut out airboxes, removed paper filters, oh, and i had open headers at the time.. best time with the y- pipe and full exhaust is 15.02 And I'm still running factory posi 2:73 rear
Old Mar 11, 2004 | 04:39 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
14.165 @ 98.16mph
BD3
Old May 24, 2004 | 09:48 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
I went 16.21 bone stock today with an lg4. That was an average of 8 runs, on the street, not a track. I'm sporting 14 years old spark plugs and whatnot. Only mod is the 82-84 trans am ram air/ cowl induction setup.evrything else is stock. Well except for a new distributor cap ;-)
Old May 24, 2004 | 11:20 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
My best last year in the 1/8th was 9.65 @ 77mph at the track. On the gtech was a 14.5. The mods for those passes were:3.42 gears, comp cam, no cat and 3" exhaust with flowmaster muffler, K&N cone filter, and et street tires.
I put on headers and a shift kit and the best on the gtech is 14.3@98. Still have to get the chip burnt and hopefully get in the 13's.
LB9GTA
Old May 25, 2004 | 11:37 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
before the heads, torque converter, and shift kit, i went a 14.8@94mph. my cam and stock converter did not work well together. now with my heads and converter i spun the tires to a 14.4 @ 100mph on a G-tech. after i get my custom chip i am goin to the strip, hopin for some 13s.
Old May 25, 2004 | 06:04 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
back when my car had a weeohh five..it ran 14.9@93 with the factory leaking exhaust, 12 year old dry rotted tires and a T/O bearing that wouldint pop the pressure plate so teh engagements were weak (it wouldnt break them loose when shifitng)...my 60 ft was a 2.3...
over then next few weeks i added a K&N filter, flowmaster muffler with crappy press bent tubing, a set of tires, a sotck repleacment clutch/T/O bearing and ground down the egr walls...
never touched anything else...no FP or spark adjustments
after 6 runs or so i got er running 14.3's...it was all in the launch..cut a 1.95 best...after i got the launch consistant i went after a hi 13 by powershifting the **** out of it..almost got there with a 14.12@almost 96..then i pulled it out in favor of a carbed LT4...
you have no idea how many people (well drivin LX's, LT1's LS1's) i suprised...
Jake_92RS
Jan 28, 2020 10:37 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
justin57
Aug 20, 2015 07:05 PM
