New!!!! Gms Maf!
Old Mar 22, 2004 | 12:38 AM
mastrdrver's Avatar
New!!!! Gms Maf!
I dont know if anyone has seen this yet, but GMS came out with a TUNEABLE MAF for the 85-92 ecu. Here is the link. I know where to get it for less then that though.
Old Mar 22, 2004 | 01:15 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
rock on:rockon: , but i thought the 85 mafs were different
Old Mar 22, 2004 | 08:18 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Damn, $451?
I talked to ed wright on Friday. He said that there is a switch in the $6E code that goes from freq to digital or volts, and that he hasn't had time to play with it/tune a car with it yet. I asked him if I he could make a 3.5" LS1 maf sensor work with $6E and he said he could try. I could go down to tulsa and have him try it, and my car would be the guinea pig, but I'm still thinking about it. I think it would be worth it to have some more options besides going aftermarket or switching to the 730. Those sensors aren't cheap though.
Old Mar 23, 2004 | 12:43 AM
mastrdrver's Avatar
I know where to get one for $299 for a limited time, and no not from me.
Old Mar 23, 2004 | 09:38 AM
mikobu3's Avatar
can;t you adjust the maf with prom tuning ,
just ordered all my prom tuning stuff from craig moates , awsome guy to talk to for help
Old Mar 23, 2004 | 01:50 PM
mastrdrver's Avatar
Originally posted by 89gta383
Damn, $451?
Ok, I found this site. One of the advantages you get is that you can tune the engine without a chip. Kinda like the Maf+ tuners for the LTx and LSx engines.
Old Mar 23, 2004 | 02:16 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
What size is this sensor, it looks like the stock housing?
Old Mar 23, 2004 | 02:45 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
It looks like they used Wells core, Vader has put some info about Wells unit here
Old Mar 28, 2004 | 06:18 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Pretty cool, that beats the heck out of tuning with fuel pressure.
Old Mar 28, 2004 | 06:31 PM
mastrdrver's Avatar
From what I have been told, it is the same size as stock.
Old Mar 31, 2004 | 02:16 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
The main problem w/ the stock size mafs on these cars isn't that they only read to 255 g/sec, but that the 2.5" isn't big enough for good hp numbers. It starts becoming an restriction too much. That is why it would be sweet to run a 3.5" LS1 Maf...
Old Mar 31, 2004 | 06:04 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
So is this like the GM MAF and convertor thing that the DSM guys use, but in the stock MAF housing that our cars use?
Old Mar 31, 2004 | 06:29 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, lets think here.
We can adjust the fuel pressure on our 3rd gen cars. The LS1 cars can not do that. By adjusting the fuel pressure, we can directly affect the WOT AFR, which is a big plus and we dont need to burn a chip for that.
I think that the adjustable MAF sensor for TPI cars is not a big boom to us, but the increased air flow would be. So, to me, the big advantage here is the increased air flow. BUT, if its the same inside diameter, how can it flow 30% more air as advertised????
I need to figure out some way to get more air without switching to speed density. I am currently biulding a 395 cu in SBC for my '87 IROCZ.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
