Engine bay clean up help
Old Mar 24, 2004 | 03:29 PM
Mike89GTA's Avatar
Anybody have any tips on cleaning up my engine bay,
Old Mar 24, 2004 | 03:42 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Find a cover for the pass. side strut. A wire separator kit with or without a braket for you plug wires will help a lot. If you can get rid of the air pump you will also clean things up when you get rid of the diverter valve. Some corrugated wire loom perhaps. Just try to run the cables and everytnihg in the most organized way. And give the engine bay a good clean up with some degreaser and water.
Old Mar 24, 2004 | 06:09 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Go carb?
Old Mar 24, 2004 | 06:17 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Yes, what he said... get those rambling plug wires organized! :nono:
But I'm not sure you wanna take off that air pump and stuff if you wanna stay legal.
And how about a new hose to make that throttle body coolant bypass a little more attractive or less noticeable.
Get to work!!!
Old Mar 24, 2004 | 06:39 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Does the AC work? If not, rip that ****e out of there. That would clear up a lot of space. You could take Petes advice and go carb and send me that intake. Other than what Firebreather suggested there's not a lot that could be done. There just isn't a lot of space under the hood of these cars.
Old Mar 24, 2004 | 06:42 PM
MdFormula350's Avatar
a/c delete
helps alot.
cruise control delete. helps alittle.
a.i.r delete, non air headers helps a bunch.
Old Mar 24, 2004 | 07:59 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
get rid of ac, get rid of the heater box, get rid of cruize control, charkoal cannister, get rid of ecm, get a carb, get rid of emmisions, now, whata difference, i just did that to my Camaro, but i opted for a new motor not just a carb...
Old Mar 24, 2004 | 10:01 PM
MikeS's Avatar
I think the biggest problem is that supersized aluminum box you've got sitting in the middle of the engine bay. Take that off and ship it to me, that will make worlds of difference!
It's amazing the difference just a good set of wire looms and elimination of the AIR systems will make. You could also look into different heater hose routing to keep them from running directly over the valve cover.
I like all the suggestions so far. I try to make it a point to give the engine bay a detailing of sorts every time I wash my car. Of course, I'm pretty lazy and don't do it like I want to, but making it a routine helps a lot.
Old Mar 24, 2004 | 11:02 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A nice cold air intake would look alot better than the stock routing... not necessarily smaller, but it looks CLEAN.
Old Mar 25, 2004 | 03:12 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
AC Delete, get rid of the smog pump, you will be suprised how much more room that you have. Here is mine:
Old Mar 26, 2004 | 11:12 AM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
I noticed one of the carb guys already had, but you can also take out the heater bypass valve. I'd say do a cold air intake, but it appears that you already have an slp cold air intake. Removing AIR is a must just for the extra space.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
