about to start modding where to start
Old Apr 28, 2004 | 08:13 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok i got the engine running top notch performance now...plugs wires, cap, rotor, o2 sensor, fuel filter, new distrubtor msd pro billet, msd 8.5heli core wires, with the bosh platnim 4+ plugs...
ok i want to do a cam i want my upper end torque and hp.....but where to start headers, exhaust, than super ram and cam or which order i want the best hp for my money and im trying to get mid to low 13's and keep it a daily driver. i pulled a 14.2 completly stock not even the throttle body coolant bypass
Old Apr 28, 2004 | 09:19 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Well Personally I would say you can hit mid 13's with a stock TPI intake. You'll need exhaust work (good headers, and probably 3" all the way back, high flow cat and nice muffler). I'd say a cam, maybe some porting on the heads, or aftermarket heads and some tuning.
You didn't say what engine you have now, I assume it's TPI since it's in the TPI section... or what times you running after your many mods.. but I think it could be pulled off fairly easily. You may want to think about some gears, and a higher stall torque converter, shift kit and possibly a corvette servo.
My guess is you'll need some suspension mods to keep yourself on the track, you might end up with too much power for your stock suspension to put to the road.
Old Apr 29, 2004 | 03:07 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
sorry its a 5.7tpi with a 3.27 limited slip posi rear end....my best 2 times are 14.2 and 14.4 other than that runnin consistent 14.5's will corvette heads bolt right on???
Old Apr 29, 2004 | 03:13 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
2800 stall convertor, big tube runners, 52mm tb, and long-tube headers with a cat-back exhaust will get you there.
Old Apr 29, 2004 | 04:22 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
If you're clippin 14.2's now, you can get to the mid 13's with Headers, good cat/no cat, Catback, and a gear reduction to 3.73s.
Tasty.
Old Apr 29, 2004 | 07:32 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
did i mention i got a t-56 in the garage ready to put in freshly rebuilt....just need a flywheel/clutch got everything else
Old Apr 29, 2004 | 08:55 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
hes a long way from needing that convertor or the TB
Old Apr 30, 2004 | 10:11 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
No he's not. He said he wants to hit mid 13's and he's running 14.2 now, and the convertor is the first mod he should do. I would leave the rear gears alone at 3.27. The only thing the 3.73's will do is eat your gas mileage if you drive the car alot. You will get a bigger gain from the convertor, headers, cat-back, runners, afpr, and tb and porting the plenum.
Old Apr 30, 2004 | 02:17 PM
wako29's Avatar
he'll do fine with just nice headers & exhaust and cold air intake. That will probably get him into the 13s.
The convertor is to much of a PITA. And that will eat gas worse than the 3.73s. Runners would be a good idea, but not required. Same goes for AFPR. Porting the plenum would be a VERY good idea. Getting a bigger TB is definetly not needed, as you could get a lot better parts for the money, and you aren't even close as to need it.
Old Apr 30, 2004 | 02:37 PM
Another potential problem with doing the converter is traction. I have a friend who was running 14.7's, and figured a new tranny and converter would get him deep into the 14's, possibly high 13's. He put in a ACT 9.5" 2400 RPM Stall Converter and a Pro-built Tranny, and now he has traction problems and can't really break into the 14's anymore. He spins all the way through first, and finally gets traction in 2nd. He also has 3.73's.
I think if you do the converter, you too might have traction problems.
Like I orginally said, I'd go for Exhaust first, with good headers and a new High Flow Cat... see where that puts you. After that, you could take either road... meaning do more engine work, or put in some gears and torque converter.
If you are planning a t-56 swap, I'd say do some engine work, port your heads or throw new heads on, port the plenum, maybe do some work on the intake base, and I think by that point you'll be closing in on low 13's.
If you do the Corvette heads, you will no longer be smog legal, as they do not have the EGR Heat Risers, I don't know if that is an issue to you. I would say you should run some thin gaskets with them, try to bump up the compression a little.
Old Apr 30, 2004 | 03:15 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
wonder what the t-56 will do to my gas mileage
best was today took it all the way down damn near ran out 15.5gallons with 222miles thats only 14.5mpg and it was all highway what the **** where is my gasmileage at damnit
Old Apr 30, 2004 | 03:21 PM
Well I'd say a t-56 will help your mileage out a bit, Seeing as it is a manual, and the 6th gear is pretty high (what are they? .68??)
I suffer from poor mileage around town, but on the highway I average 18 miles per gallon, around town I believe I get about 12.5 mpg at the best. Average per tank, which is both highway and around town driving is usually 15.5 mpg, depending on how much highway driving I do. And this is with an automatic, and a 3.08 rear end.
Old Apr 30, 2004 | 04:26 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
i got a 3.27rear end.... and the t-56 i had built has a .5 6th gear (final) so i can run 4.11 and still get good gas mileage my question is HOW THE **** DO THEY GET 17 AROUND TOWN AND 21 ON THE HIGHWAY. no matter how light i accellerate i cant do it... just did a full tune up too.
Old Apr 30, 2004 | 04:31 PM
I don't know how they get such good mileage.. a lot of chip tuning I am guessing. I did a full tune-up and rebuilt injectors, and only gained about 2 mpg for highway, nothing around town really.
I know how you feel, I have driven it very lightly and still get the same mileage... I think my cat is part clogged tho. Time for a new MAF also I thin, maybe all that would give me back some lost HP and gas mileage.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Wade787b
Sep 29, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
