just got the car back from getting modded
Old May 4, 2004 | 10:20 AM
mikobu3's Avatar
ok , just got it back from the mechanic , its a 1986 305 tpi ,
they put the comp extreme energy 212-218 449-456 112 lsa , i ported and polished the 416 heads , 1.94 intake valves, new springs , 3 angle valve job , dynomax headers ,
guys i have the chip equipment for burning proms , i never touched the fuel pressure , its still runnin stock , is that why my car is a dog off the line?
the 305 tpi had 18 000 original miles before this wa done
please help thanks
Old May 4, 2004 | 10:57 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
could be...mosdef need some tuning
other than off the line, how does the car feel?
Old May 4, 2004 | 12:08 PM
mikobu3's Avatar
just got back from a 1 hour ride with it , it feels great no pinging lots of power , i thought it would have been alot worse with stock chip in there ,
i notice after the car warms up and you put it from park into drive the idle drops and the car dies , also throws the ses lite , i have no scanner so i don;t no what code it is but i bet its a lean code
Old May 4, 2004 | 12:53 PM
mikobu3's Avatar
also noticed a sluggish off the line power , maybe i am expecting to much from the 305 ,
Old May 4, 2004 | 01:56 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: just got the car back from getting modded
Originally posted by mikobu3
... i never touched the fuel pressure , its still runnin stock , is that why my car is a dog off the line?
Yes.
You will probably need more fuel pressure to start with. Then you will need to retune the ECM. A lot. Don't expect big things until you tune.
Old May 4, 2004 | 05:15 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
maybe, but if i wont ruin your dreams if you wont ruin mine...lol
modding the 305 seems to take away the low end of these motors.
Old May 4, 2004 | 05:22 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It needs tuning. :werd:
Old May 4, 2004 | 05:58 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Originally posted by D Stroy H8
It needs tuning.
It's a MAF setup correct? If so he shouldn't need that much tuning. MAF is more forgiving.
That's my take on it though.
Old May 4, 2004 | 06:03 PM
mikobu3's Avatar
yes maf
i think it needs more fuel , i will do that threw the chip , i also think the 305 needs a 2400 stall , will let you no when i get this going
Old May 4, 2004 | 06:26 PM
lokoRS's Avatar
Car: 89RS
U definitley need bigger gears/posi, if u dont already have them. And u definitley need tuning.
Old May 4, 2004 | 06:52 PM
mikobu3's Avatar
lol , i got 3.42 gears and i got posi
Old May 4, 2004 | 11:01 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a 305tpi as well. I put in a comp cam and I actually was slower until I started fixing the exhaust. My engine will heat a bit when idling and run very rich too. But on the good side I am making more power and have headers to install when I have time, then the power will come!
LB9GTA
Old May 6, 2004 | 02:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Whats the SES light on for? I modded my 89 350 with al. heads lpe 219 cam and and super ram and have no problems driving on the stock chip and with no ses light and its more powerful. I think your ses light problem is causing the problem. I could see if it was a sd car but with maf you should have no probs. Thats not even a big cam.
Old May 6, 2004 | 03:00 PM
That's how I feel about it, MAF systems are fine with changes, they can actually measure the amount of air going into the engine. I heard about people running a chip, which is pretty much stock, except for the 1st MAF table, and the only reason they changed that was to get it to idle smoother.
I heard someone on the board that was running a 383 with a Accel Super Ram and a custom chip, and just for the hell of it he put in his stock 305 chip to see if it would run, and he said it ran pretty alright, except for the idle.
Old May 6, 2004 | 03:02 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Sounds like you need a higher stall from the converter. I'm running 2800 with my 305.
Old May 6, 2004 | 03:47 PM
mikobu3's Avatar
i will start uning up the chip
there are a few guys on here not giving names saying that modding a 305 tpi will make 360 tourque , i have a hard time believing that , but when i get the idle down pat i will let you all no ,
anyone no where i can buy a good scanner , i am in canada
thanks
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
matthew911
Aug 12, 2015 09:38 AM
drathaar907
Aug 6, 2015 04:20 PM
