Still having problems
Old May 23, 2004 | 06:38 PM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
Ok I fixed some of the problems i was having before but I still have 2 left. For one when I start the car it revs to about 1700 and within 3 secs it is down to about 1000. I do not think it should do this. And for two when I stop at a redlight (or anywhere for that matter) after i have been cruising at about 1800 RPM it idles at about 900 then after 2 secs it idles to about 650 (where it should be). We have fixed so much on this thing and it is really getting on my nerves.
Right now it has a new PROM, MAF, IAC, TPS and O2 sensor.
My only guess would be that my modifications are hurting it. I have a stock CIA out of an 88 formula, with K&N filter, air foil, deleted AC, deleted smog pump belt, deleted cat, and an 80 series Flowmaster muffler.
Could it be faulty injecters b/c they are ticking?
Old May 24, 2004 | 06:19 PM
ss85tadude's Avatar
Car: 85 Trans Am
Anyone? Right now I am stuck.
Old May 24, 2004 | 07:46 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Mine does the same thing....still I've replaced everything. I re-set the IAC, tps etc..... It still does it. I'm intrested to hear any ideas too.
Old May 24, 2004 | 08:22 PM
ss85tadude's Avatar
Car: 85 Trans Am
I just did some research, and found that an ignition module could cause this. What do you guys think? For 17 bucks I think I will replace it anyways. Does any body have a pic of what the ignition module looks like or where it is located? I do remember seeing one when I replace the distributer cap, rotor, coil and wires, which I replaced with stock units.
Old May 25, 2004 | 01:09 PM
ss85tadude's Avatar
Car: 85 Trans Am
Ok, I found it, I was reading somewhere and they called it the distributer module So I thought they were 2 different things.
Old May 25, 2004 | 10:01 PM
ss85tadude's Avatar
Car: 85 Trans Am
Do you guys think this could be a timing problem?
Old May 26, 2004 | 04:08 PM
ss85tadude's Avatar
Car: 85 Trans Am
Anyone?
Old May 27, 2004 | 08:12 PM
ss85tadude's Avatar
Car: 85 Trans Am
Somebody? Please
Old May 27, 2004 | 08:36 PM
biff85ta's Avatar
Car: 04 Vette
Mine does the exact same thing and I have not found a single thing to cause it.
Old May 27, 2004 | 08:51 PM
ss85tadude's Avatar
Car: 85 Trans Am
There has be something causing this. Has anyone had this problem and was able to fix it?
Old May 27, 2004 | 10:44 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I had a crazy idle problem and turned out the distubtor was going bad. Eventually, it just completely broke and the car would not start at all. The magnetic pickup likes to fail in these cars and when it starts going out it swings the timing all over the place causing an erratic idle. This may or may not be your problem but just pull the dist cap off and inspect the magnetic pickup if is all rusted and brittle its on its way out. And personally I just put a whole new MSD distributor in mine it was much easier.
Old May 28, 2004 | 08:33 PM
ss85tadude's Avatar
Car: 85 Trans Am
Well I have a steady idle, but it just revs high when I start the car. Could it be the Fuel Pressure Regulator? How do I test the FPR
Old Jun 9, 2004 | 03:40 PM
biff85ta's Avatar
Car: 04 Vette
I think it is just a function of the computer learning were it is on the restart and there is more than likely nothing that can be done about it.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
