need help my car keeps dying
Old Jun 6, 2004 | 11:43 PM
83 camaro racer's Avatar
Car: 87 trans am
Engine: 305 tpi
I have a 1987 trans am 305 tpi with a 700r4. I powerslid my car around a corner and after i pulled it out of it the car died. Then on the way home the car kept dying if the tach dropped below 1,000 rpms. Ive had a rough idle and the tach jumping aroun 250 rpms or so the last couple of days. It has a new fuel filter,new plugs,new wires,cold air intake, oil changed 200 miles ago,cap, and a new rotor. The car will start once and a while and idle really rough other than that you have to give it gas to start and keep your foot on it otherwise it dies. After you do get it to move if the car drops below 1000 rpms the car will die. Im guessing its the fuel pump thats causing this? Would i be correct in assuming this or could it be something else? Oh yeah the trunk smells like gas really bad and theres a boiling sound in the rear of the car after you turn the car off.
Old Jun 10, 2004 | 06:57 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Are there any codes?
I'd check the fuel pressure before tearing into a pump replacement job.
Old Jun 10, 2004 | 09:09 PM
Car: 87 trans am
Engine: 305 tpi
no there is not any codes. any idea what it could be?
Old Jun 11, 2004 | 08:28 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
dying
Sounds Like the fuel pump. Get a fuel pressure gauge and test it .
You may have ripped that corner and starved your fuel pump for a second wich in turn helped it kick the bucket since it was due to go out any day now.
Old Jun 11, 2004 | 09:24 AM
Car: 87 trans am
Engine: 305 tpi
i was driving down the road and my car started jumping like it was out of gas on tuesday and then it died and it has plenty of gas.
Old Jun 11, 2004 | 09:29 AM
Car: 87 trans am
Engine: 305 tpi
also i was wondering what my fuel pressure should be at. its a 305 tpi
Old Jun 11, 2004 | 09:56 AM
robsgta's Avatar
305 tpi
It should be around 40 to 42 psi stock. at idle
When you test the pressure it also needs to stay there strong. You dont have to start your car to test it just turn the key to accesorries on.
Do you still hear your fuel pump prime when you turn your key???( the 3 second buzzing sound from the back of the car) when you turn the igniton power to on.
I have tested a few pumps before by just pressing the schrader valve in some cases after allowing the pump to prime and seeing if the pressure is strong enough to spray hard or just bairly trickle out.
Extremly hard spray= good pump
bairly trickle out = bad pump
But some times you can still have some pressure but not enough to fire an injector so if your not sure what to look for get a Gauge some auto places let you borrow them like auto zone. (with deposit)
Old Jun 11, 2004 | 09:59 AM
Car: 87 trans am
Engine: 305 tpi
yeah it primes my cousin has a gauge ill have him bring that over and check this.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
