cold air inatke
Old Jul 6, 2004 | 11:56 AM
91GTA350's Avatar
cold air inatke
What does everyone suggest for a cold air intake on a 91 trans am. I made a custom one out of pvc, but me being the dumba** that I am at time sdidnt think the overflow nipple on my radiator would snap off from the weight, but it did.
I saw a really nice cistom welded setup for sale in the classifieds here, but it looks to be th esame size as my ild air intake was, and i dont think it will clear the valve on the radiator. Any ideas?
Old Jul 6, 2004 | 12:15 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I haven't had any problems with my custom one. 3" mild steel piping, silicone hose from http://www.bakerprecision.com, and an S&B filter.
Old Jul 6, 2004 | 01:55 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
What filter did you use? I'm making my own piping but have no idea how to find a filter to put on the end of it (hopefully that will fit over a 3.5" pipe)
Old Jul 6, 2004 | 02:05 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Which ID tubing did you use to fit over your TB?
Old Jul 6, 2004 | 02:11 PM
vernw's Avatar
I'm actually using an LT1 bellows
Old Jul 6, 2004 | 04:04 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I believe I am using the k&n cone number 0920. I think its the 9". It will fit over 3.5" pipe. You can call and ask or check their web site. I am also using the LT-1 ceramic elbow.
Old Jul 6, 2004 | 04:50 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Does the aftermarket lt1 intake elbow (the metal one in summit) stick out far enough over the pulleys and such?
Old Jul 6, 2004 | 09:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have a 1989 Trans Am with TPI and I just ordered the LT1 elbow from Summit. I happened to have a piece of of 4 inch hose that I can use to extend the LT1 away from the throttle body. The hose is long enough so that I can cut it to length and it will clear the pulleys and serpentine belt. I don't know if the one they supply in the kit is long enough. I should get the kit tomorrow. As I understand it the inlet side is 3.5" in diameter. This should make for good air flow and is superior to the stock Trans Am piece. Allen
Old Jul 7, 2004 | 02:19 AM
yes it will clear.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
