Just noticed Crank Pulley Wobble on LB9 - What to dO?
Old Jul 10, 2004 | 07:33 PM
C4 Suke's Avatar
Car: 1990 IROC
Engine: LB9
My crank pulley is wobbling pretty bad and the car is idling rough and shaking... how bad is this... what effects can it have on my (118k miles) 5.0 LB9 TPI... auto... ?
Would replacing it fix the problem? Thanks!
Suke
Old Jul 10, 2004 | 09:20 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
By crank pulley, I assume you are talking about the harmonic balancer. It is made of 1 metal hub with a metel ring around it with a thin rubber devider. This is what absorbs the vibrations created by the engine. In time the rubber can wear and the unit does not perform well. You can replace for $30-$40. Need to do before the whole thing comes apart. Most times when that happens the inner hub breaks off and drops into the oil pan taking the timing chain with it.
Old Jul 10, 2004 | 09:30 PM
C4 Suke's Avatar
Car: 1990 IROC
Engine: LB9
I'm talking abou #4 here:
(thanks to Midnight Sun for that pic)
That's connected to the harmonic balancer right? So if its wobbling it would be the harmonic balancer I would have to replace?
How hard is it ?
Old Jul 10, 2004 | 09:33 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
You need to determine first what is actually bent. Wether its the crankshaft snout, the pulley or there's something wrong with the Balancer. Remember the job of the balancer is to smooth out the rotation of the Crankshaft. If this falls to happen, it can snap the crank in half. If it's the pulley, your going to have problems with the belts, sooner or later. If its the snout, I'd go ahead and replace the crank and rebuild the bottom end while your there. In the long run you would be time and money ahead. (IMO)
Bill
Old Jul 10, 2004 | 09:37 PM
C4 Suke's Avatar
Car: 1990 IROC
Engine: LB9
Damn, I hope its not the snout... and rebuild? I doubt I would I need the car on the road ASAP, plus I don't know crap about how to rebuild, it would probably end up running worse!
So I guess to determine this I would have to remove the pulley and just get a close up inspection of it?
Old Jul 10, 2004 | 09:53 PM
Car: 77 El Camino
Replacing the balancer is fairly simple. Take the belts off.Remove the center crank bolt and then the smaller bolts holding the pulley on. You'll need a Harmonic Balancer puller, its shaped something like a "Y". Some people like to put the crank bolt back in minus the washer at this point. You'll use a bolt at each leg of the "Y" and bolt the puller onto the balancer. Then there is a big screw that screws into the center of the "Y" This center screw will then be tighten down against the crank bolt or whatever your puller uses, and by turning the screw it will draw the balancer off.
Important Notes: Some like to use a anti-seaze compound between the snout and the inside of the balancer. My Fluidampner came with it. And remeber to PROTECT the crankshaft threats, this is probibly the most inportant part.
Speaking of Fluidampner I got a kit from Summit several years back which included everthing: Dampner, Timing Mark and a very high quality puller/installer. Complete with instructions. Just an idea.
Bill
Old Jul 10, 2004 | 09:58 PM
Car: 77 El Camino
Snouts usually don't bend unless you've been jacking up the car by it or have the belts way too tight. And Pulleys just don't bend either, for that matter. My guess would be the balancer. But make certain first.
Bill
Old Jul 10, 2004 | 10:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Try snugging down the 3 pulley bolts and the center balancer bolt. If that doesn't fix it, remove the assembly and replace it. It may or may not be a case of the outer ring slipping. However, keep in mind, if the pulley is wobbling, then one of 2 things is bad. Either it's not bolted down right or the entire balancer assembly is loose/broke. The pulley is mounted to the inner hub, the same part that bolts to the crank.
Old Jul 10, 2004 | 10:08 PM
C4 Suke's Avatar
Car: 1990 IROC
Engine: LB9
Hey thanks for all the info elcamin0_77us, it'll help me out a lot. Stekman I'll see if its just not bolted up right or something like that, it sounds like a much easier fix . I'm going to try to compile all the parts needed from AutoZone, since I can get a discount from there.
I don't know how this started I just got the car, hopefully the previous guy (who did seem desperate to sell it) didn't mess up the snout.
Old Jul 10, 2004 | 10:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Do you know if he removed the balancer at all (the previos owner). The balancer can go on with a slight tilt and that would make everything wobble.
Old Jul 10, 2004 | 10:16 PM
C4 Suke's Avatar
Car: 1990 IROC
Engine: LB9
No I can probably email to ask him, there were lotta things wrong with the car that I didn't even think to check, pretty stupid of me... like the cd player not working, he mentioned it was new, so I assumed it would work and didn't care to check it, boy was I wrong. I also assumed the passenger side door was lockable/unlockable via the actual key, but I didn't notice that either, I should have checked when he already had it open for me! He pretended to be honest with me and told me all the things that were wrong, except for the major ones!
Old Jul 10, 2004 | 10:28 PM
C4 Suke's Avatar
Car: 1990 IROC
Engine: LB9
DORMAN 594-012 1 YR $49.99
PIONEER DA-3071 1 YR $85.99
O.E.M. #12551537
PIONEER
HEAVY DUTY DA-3071-HD 1 YR $169.99
PIONEER
HIGH PERFORMANCE 872002 1 YR $164.99
These are my choices... anyone know whats so high performance bout that pioneer high performance? I think I'll go for Dorman if the problem is in fact the balancer.
Old Jul 11, 2004 | 10:42 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Sounds like the guy I bought my first car from. Sold me a '90 Plymouth Sundance w/ 147k miles on it. I put 9K on it before I totalled it. Needed a LOT of work, and I wish I had replaced the transmission mount. That was stupid of me not to do...ended up messing the tranny up a bit, but I never had to worry about it since I totalled it anyways. Massive brake failure followed by locking up the steering wheel. Now though, the guy and I are pretty good friends (we're co-workers at an apartment complex). Oh yeah, on that car, my passenger side wouldn't work with the key at all either
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Formula_88AE
Sep 3, 2015 01:47 PM
