What would cause Oil Pressure to go so low?
Old Jul 20, 2004 | 09:21 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
what the title says...
Old Jul 20, 2004 | 09:31 PM
5SIZ's Avatar
Car: 1987 IROC-Z
maybe an oil pump taking a dump....
Old Jul 20, 2004 | 09:37 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Maybe the main/rod bearings taking a dump....
Maybe just the oil pressure sending unit taking a dump (very common.) If it's not making any knocking noises, replace this first.
Old Jul 20, 2004 | 09:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you verified the pressure via mechanical gauge?
Old Jul 21, 2004 | 02:07 AM
HamSpiced's Avatar
Nope... havent verified it..
Sending unit is about 6 days old.. previous one was 6 months old..
Old Jul 21, 2004 | 02:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Might want to do that.
i've had a bad sending unit out of the box before. That sucked.
Old Jul 21, 2004 | 12:54 PM
TheGreatJ's Avatar
I had 3 in a row once. That's when I quit buying GP Sorensen parts.
If the pressure reads the same with the old and new senders, then they're probably accurate. The gauge itself may be going bad (3rd gen gauges are notorioulsy inaccurate) or you may have an actual problem. If the senders read the same I'd check it against a mechanical gauge, to verify the dash gauge's accuracy.
Old Jul 21, 2004 | 12:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Mine was GP, too ...those darn blue and white boxes. Avoid GP.
Old Jul 21, 2004 | 01:12 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
No oil in the pan could cause pressure to be low..
Sorry, someone had to say it.
Old Aug 1, 2004 | 02:46 AM
HamSpiced's Avatar
Nah theirs oil in the pan
Smartass...
The car will start with around 30-40 psi, after normal driving it drops to around 15-10......
Old Aug 1, 2004 | 04:50 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Is this what the dash gauge says or is it the mechanically verified pressure?
Old Aug 1, 2004 | 04:54 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
10 - 15 at idle or at speed?
Old Aug 3, 2004 | 05:48 AM
HamSpiced's Avatar
This is what the dash says, im going to assume that it is correct.
idle and speed. As i hi tthe throttle the oil pressure seems to slowly go up...
Old Aug 3, 2004 | 09:28 AM
kevinc's Avatar
Car: 1982 Z28
Hard to say the likely causes, not knowing much about your car...other than it has a fancy sig picture so it must be slow...
So...what mileage is on the engine, what brand and weight oil are you running, and what filter brand and part# are you running?
Old Aug 3, 2004 | 11:54 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
That was the main reason that I read this one first at lunch... I wanted to say it.
Old Aug 3, 2004 | 03:40 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Smartass...
the question though I have is where is the pan?
you can have a full 5 qts of good quality synthetic oil in there and your not going to have much oil pressure if it is just sitting there on your shop floor
might be part of your problem
Old Aug 3, 2004 | 03:53 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
things though that can cause problems
leaks... they are decent at bleeding pressure
don't know if you guys have it but on my car there is a oil bypass for the when oil is cold it doesn't go through the e-shaft (crankshaft) to help with warming the motor up. when the bypass is open it has a low oil pressure. so just think if it sticks in bypass mode you get a constant low pressure
you can also have problmes if places where there are oil holes like the rods mains, piston and such have the clearance worn out
oil pump
blockage in the screen on the oil pump
so might want to check that stuff out
Old Aug 4, 2004 | 01:01 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
10 psi is within normal range at idle. General rule of thumb is at least 10 psi per every 1000 rpm.
The factory gauge is not at all accrurate. Always verify with a mechinal gauge before ripping into an engine for oil pressure problems. Again, there is no need to worry with 10 psi at idle.
Old Aug 4, 2004 | 05:00 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I was amazed when i went on Mitchell on Demand the other day and saw taht oil pressure spec for my 89 TPI is 6psi @ 1000rpm!!!
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
