tpi starts then wont run
Old Jul 25, 2004 | 01:55 AM
waldothejuggalo's Avatar
Car: 89 gta
Engine: 5.7 tpi
Transmission: automatic
hay i have a 89 g t a .tpi when i start it it will run for a sec the it will die . my fuel pressuer is good so it isnt my furl pump.i checked my injector and one is running at 2.5 to 3 ohms the rest r running at 12 to 17 .so im going to change the injector if that dont work i dont know what it will be need help.
Old Jul 25, 2004 | 04:52 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
You should post this on the ECM board. I think the bad injector will knock out the injector driver in the ECM and that's why it dies. After you replace the injector you should be fine, but I'm no computer expert.
Old Jul 25, 2004 | 10:45 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Usually fire or fuel. Sounds like the bad injector. If that does not work make sure you have a nice blue spark when cranking the engine over. Ignition module???
Old Jul 25, 2004 | 11:51 PM
Car: 89 gta
Engine: 5.7 tpi
thanks guys i put the new injector in and it works good now .but now i can fined out this noise that my car is makeing .it sounds like it is comeing from the lifters.what do you guys think
Old Jul 26, 2004 | 09:05 PM
89Warbird's Avatar
Engine: 389 CID TPI
Need more info to hazard a guess.
Old Jul 26, 2004 | 11:44 PM
evelkneivel001's Avatar
Car: 87 GTA
Engine: 383 Stroker
Transmission: 700 R4
I had the same problem not long ago.
If you have a MAF sensor, try unplugging it and see if it stays running. That is the easiest thing to try. You may want to get a book called "TPI Swappers Guide". It has a reallygood troubleshooting guide in it and has helped me find alot of problems. good luck!
Old Jul 27, 2004 | 08:26 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
try the maf. and the connection, then vacume leaks assuming u have proper timing and fuel. and of course spark. any codes?
Old Jul 27, 2004 | 09:27 PM
Car: 89 gta
Engine: 5.7 tpi
thanks to all. i got it running. one of my injectors where bad.i changed it and got it running.now all i have to do is find out where this ticking noise is comeing from.it only happends between 1500 and 2000 rpm's.it was doing it befor my injector went out
Old Jul 28, 2004 | 12:33 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Let it idle, open the hood in the dark and look for spark leaks, if none increase rpm to 2K and look again.
I'd also replace the spark plug of the cylinder that had the bad injector.
Old Jul 28, 2004 | 09:37 PM
Car: 89 gta
Engine: 5.7 tpi
thanks ill give it a try
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
