tbi to tpi swap
Old Jul 27, 2004 | 09:16 AM
redlightrunner's Avatar
tbi to tpi swap
help give me all ur info i have a 92 rs and i want to put a 305 tpi on it and the camaro is a 305 tbi and will the 305 tpi fit on any year sbc??? jus give me all ur info thanks
Old Jul 27, 2004 | 10:27 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Well all (except Vortecs) '87-up heads will work with the '87-up intakes. Seeing as that is TBI, your biggest gains will be noticed by swapping the heads with those out of a TPI 305 car as well. The stock swirl-port heads are crap. TPI will be amazing for torque. How soon are you looking to do this? I should have ported/pollished intake base, runners, and plenum off of my car in a few weeks (I'm waiting for my LT1 intake to arrive).
Old Jul 27, 2004 | 04:45 PM
camarochevman's Avatar
how much u want for all that stuff
Old Jul 27, 2004 | 04:46 PM
i need all the stuff for the tpi swap
Old Jul 27, 2004 | 10:53 PM
Car: 1997 Corvette
I don't know, but its not going to be all of it. I'll have hte fuel rails available as well. You'll still need wiring harness, ECU, and injectors.
Old Jul 28, 2004 | 07:55 AM
are u gonna sell me the tubes that run down to where the injectors are the top part where the air goes in and then the bottom part where it goes to the heads sorry im not verry good at tpi
Old Jul 30, 2004 | 04:19 PM
DA 89 CAMARO's Avatar
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
wiring harness
I need a wiring harness for 89 T.P.I
Old Jul 31, 2004 | 01:28 AM
Car: 1997 Corvette
Yeah, exactly, and I was planning on porting it as well as pollishing it (if you wanted it pollished as well). I might actually get new injectors as well so I may be able to include them with it.
The "top part where the air goes in" is called the plenum.
The "tubes that run down to where the injectors are" are called the runners.
And then "bottom part where it goes to the heads" is called the base.
Also included would be the fuel rails (which connect to the injectors to provide fuel)
Just so you know
Also, you would need a throttle body since I'm keeping my stock one for my intake swap. They can be had pretty cheap though usually (all you'll need is a stock one).
ALSO (lol), in even a few more weeks I should be getting another set of 305 TPI heads identical to mine. I'll be porting those, rebuilding them, and then installing them on my car. Then I'll have my stock 305 TPI heads that I could also port for you if you wanted...
Just PM me or email me at dean@xibase.com and we'll talk more about this
Old Aug 2, 2004 | 10:06 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I am doing the same thing right now on my 92 and let me tell you, it will take some time to get all the little fittings and such needed. you think you have everything and then you need another hose or bracket. this sucks.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
