Throttle Body Question
Old Aug 8, 2004 | 12:49 PM
GroundPoundinZ's Avatar
Just checkin' to see what the difference is between the 85-88 Throttle Bodies and the 89-92's. I know when you order aftermarket TB's it has those two applications. I have a Mini-Ram intake....if that makes any difference.
Old Aug 10, 2004 | 08:52 PM
Anyone?
Old Aug 10, 2004 | 09:20 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
The big difference is the way the throttle cables are attached....mainly the arm where the cable hooks on is different. Plus the cables themselves are different at the ends.
Early TBs had the cable secured on the throttle arm with a small clip.
On later TBs the cable has a plastic piece on the end that you just snap into place on the throttle arm.
Old Aug 10, 2004 | 09:30 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There is also a difference in the IAC passages.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
