which RTV to use?
Old Aug 20, 2004 | 07:08 AM
rrmorris67's Avatar
Car: 1986 Z28
Engine: 305 tpi
Transmission: 5 speed auto OD
which RTV to use?
Please excuse the simplicity of my question here. I am new to engine repair....I am in the middle of an intake manifold repair on my '86 305TPI and I am unsure as to which RTV would be the best to use on the block and around the water jackets. I bought ultra blue, but I have seen postings about guys using ultra black, black aircraft grade, or ultra grey or even something called ultra copper. Also, is permatex 2 the best thing to use as thread sealer on the manifold bolts? I've got one chance to do this right and don't wanna screw it up. Thanks!
Old Aug 20, 2004 | 07:35 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
ultra blue will work out great. I have used ultra blue, but lately have switched to ultra black, so that the blue doesn't stick out when I'm building 'show car' type stuff. they are very similar in characteristics, you could almost say they are the same just different colors.
never used permatex 2 for intake bolts, you could just as easily through a smudge of ultra blue on the threads and call it a day. really, only the middle 4 bolts really require any thread sealer, but i usually never see an issue with leakage.
good luck!
Old Aug 20, 2004 | 07:47 AM
rrmorris67's Avatar
Car: 1986 Z28
Engine: 305 tpi
thanks for the help! With the wife and kids around hopefully I'll "git r done" before the first snowfal. Took me a day to tear it down and it will be 3 months putting it back together.
Old Aug 20, 2004 | 02:42 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I like the grey Hylomar import gasket maker myself. That stuff works really well, but the ultra blue or black should work as well.
Old Aug 20, 2004 | 02:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Blue, black, gray or even ultracopper is ok...
just as long as its permatex.
permatex makes some great stuff.. theres alot of other crap RTV out there.. i know there are other companys that make good sealers, but i know permatex works, and you can buy it everywhere cheap.
btw:
ultra copper is high heat: good for exhaust stuff, like EGR blockoff plates, ect..
ultra black is the most oil resistant: good for when you cant get somthing perfectly clean before you assmble it... also its hard to see since its black.
i dont recall off the top of my head what blue and gray are "better" at, but i like gray because it blends in with alum parts.. makes it look neater.
Old Aug 20, 2004 | 06:44 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Blue is supposed to be the most coolant-resistant of the RTV's. Personally I use black on everything except exhaust, which I rarely feel the need to use RTV on anyway. I also like to just rub a little black RTV into the threads of the intake bolts instead of using a thread sealer.
Old Aug 21, 2004 | 03:05 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Ultra Blue! For exhaust, use Dead Soft aluminum gaskets and you don't have to worry about sealer.
Old Aug 23, 2004 | 08:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
umm, just FYI.
when i said exhaust, im talking about when you need to seal a custom blockoff plate, like on LS1 cars.. or when you have a slip fit header tube and need it to seal.
you DONT use it on exhaust manifold gaskets or collector gaskets.
Stangski09
Sep 7, 2015 05:21 PM
exdog
Apr 2, 2002 10:01 AM
mcconahay37
Sep 9, 2001 04:41 PM
ColinOpseth
May 4, 2001 04:29 PM
TomP
Feb 27, 2001 09:58 AM
