Cant get new motor to run right
Old Aug 21, 2004 | 09:41 PM
357tpirocz's Avatar
Please help me come up with some new ideas. I have my new motor in my 88 IROC. Its a .040 over 350 with slp headers, comp cams extreme energy cam(designed for tpi)ported L98 heads, plus the usual tricks and freebies. Car will start and drive but falls on its face over 3000 rpm. Car kind of stubles a bit when cold but will drive okay when warmed up as long as you just slowly cruise. Smells pretty rich out the tailpipes. The car sat for 3 and a half years while waiting for funds and time to do the new motor. I changed the fuel filter but dont have a fuel pressure gauge. Car really doesnt drive like it did when the fuel pump went out. Do you think there is some crap clogging the sock on the fuel pump or there are deposits on the injectors or can anyone give me any other ideas. I wish I had thought to drain the fuel before it sat but thats hindsight. Any ideas would be greatly appreciated.
Old Aug 21, 2004 | 11:48 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
First of all, change your GAS. 3.5 years!!!!! Get that **** outa that tank...
BTW, what does "comp cams extreme energy cam(designed for tpi)" that mean???? Give the specs.
Did you do any Prom work or buy one of those snake oil EPROMs???
If you don't mind dropping the fuel tank, it might be a good idea to make sure there are no obstuctions, but its not my first choice for kicks on a Saturday afternoon!! And you could pull your injectors off and send them out to be cleaned and flow balanced, not a bad idea if they are old as well...Fuel can cause parts to stick after a while...
Old Aug 22, 2004 | 04:18 AM
Morley's Avatar
Replace all your cheap sensors....CTS, MAT, O2 etc. I'd start with CTS, it has been known to cause just what you describe.
Old Aug 23, 2004 | 05:02 PM
357tpirocz's Avatar
I did drain all the gas and have run several tanks through. Definately has good gas now. Cam specs 264 intake 270 exhaust duration, .487 intake .495 exhaust lift. Will try some of the sensors.
Old Aug 23, 2004 | 05:03 PM
357tpirocz's Avatar
Also still has the stock prom. Just read the article on making your own prom and I will probalby try that after a get this sorted out.
Old Aug 23, 2004 | 06:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Hard to say anything about the fuel without a pressure gauge, but that is definity a possiblity. I'd say a good tuning would probably help it out.
What cam is this specifically? grind number?
Old Aug 23, 2004 | 06:21 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I want to know more about that cam too. It almost sounds like it is going to be pretty nasty. If you can find the cam card, post all the info or get the CC part #.
Good to get all that old gas out, fresh gas is definately needed after all that time. Try to get a fuel pressure guage on it if you can.
Old Aug 24, 2004 | 03:37 PM
357tpirocz's Avatar
Cam grind number CS XR264HR-ten, had to type ten because the one key on my keyboard will not work
Old Aug 24, 2004 | 09:26 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
That's a pretty decent camshaft for a mild setup. Buddy had it in his 355 TPI. You will need to read here to get it to run correctly though: https://www.thirdgen.org/techbb2/for...?s=&forumid=16
It will need a custom tune for sure!
Oh, also, hold down the alt key and type 049 until you get your keyboard fixed. 1 <like that
eightsixseven
Dec 16, 2024 01:50 PM
jhawkeye
May 25, 2022 06:33 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Elliswon
Aug 10, 2015 12:33 PM
squiggy2
Aug 9, 2015 09:30 PM
