Summit TPI Cam specs
1 Post
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Hi all, I was looking to get the Summit TPI cam for 86 and earlier engines, p/n SUM-G5000. I did a search, and it sounds like it's a great cam for the price, and it comes with matching springs and all the lifters.
I did a search and could only find topics from people who said they were in the process of putting one in, and I couldn't find any topics about what kind of performance increases they noticed. Also, i want a nice idle; something lopey so it sounds mean and cammed out, but not too overdone.
Anyone install that cam and can give me their opinion? BTW, it's going in a 1985 305 TPI.
Kev
Kev
Here's what I found.
Summit cam
Advertised duration: 268 intake/278 exhaust
Duration at .050 in. cam lift: 204 intake/214 exhaust
Gross valve lift: .420 in. intake/.442 exhaust
Lobe separation: 112 degrees
85 TPI cam:
1985 (L69 & LB9)
Duration @ 50: 202/206
Lift (1.5): 403/415
LSA: 114.5
GM Part #14088843
It's got a little bit more duration than an L98 cam (especially on the exhaust), more lift, and a tighter lobe separation angle.
Summit cam
85 TPI cam:
1985 (L69 & LB9)
Lift (1.5): 403/415
LSA: 114.5
GM Part #14088843
Car: 89 Formula
Engine: 355
Had that cam in a GM LM1 (350 ci, 8.5/1 comp) carb'd crate eng, pulled to 4500 no problem so it should work well with a 305.
Re: Summit TPI Cam specs
I know this is an old Post but I put this cam in my car in 2010 and my house burnt down while I was stationed overseas with all my receipts and my cam card so can someone please post the cam card with with the valve event timing for this cam SUM-G5000 I'd be extremely grateful
Wow, super old post... but in case someone is searching. I too used this cam in my 86. When I broke my 305, this cam went in my 355. Good budget cam that I matched with 1.6 Roller Tip Rockers. I used the SLP runners, port matched the base/plenum to the runners (Siamesed the plenum to match), 58mm TB (why I don't know, seemed like a good idea back then), and a host of other mods. Full exhaust headers back, 2200 stall converter and shift kit, etc. Idle was barely different than stock. Powerband in this set up pulled steady to 4800-5000 RPM and could effectively pull to 5200 or so RPM in lower gears. With a 700R4/2.77 combo it would pull on the LT1's of the day. Which isn't a bad upgrade for a 305 86.
Was a lot of fun. I miss that car. Sold it to get a TTA to rebuild, and the kid I sold it to got hit by a dump truck. He was fine, the car was toast.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
This is good this got brought back. I am looking to start to acquire parts for a similar build. Kyle, did you do heads ? Was the base you port matched stock? Did you port the plenum? I got a set of AS&M runners and going to port a plenum to match. I want a stock look so I did not get the SLP style.
I found an old 350 2 bolt block with balancer at a local garage. Bought a crank kit from Parts America. Had the block cleaned, bored, honed, line bored, magnafluxed, and put the new crank kit it.
my 305 spun a main, so the rods were good and got reused with new bearings and fasteners. New pistons and rings for .030 over.
Heads were re-used from the 305. 1.94 intake valves. They were "HO" heads and I really couldn't afford new. I re-used the springs and they already had the 1.6 Ratio roller tip rockers on them from a previous round of mods so they were re-used. Definitely like 93 octane the best.
IIRC timing had the be set at 5* BTDC rather 6 to stop knock in upper RPMs under load.
I never had the money to get the 9bolt gear swapped because I would have needed the ring/pinion/carrier and install kit and there was no way I had the tools to do it myself back in the day. I was saving for that when my engine let go beating a 5.0 Fox Body on high end.
so the build as it sat. AC removed the right way including smooth panel on the firewall. Shorty headers, custom true Y pipe, 3" exhaust, American Thunder dual outlet Flowmaster. Summit Cam that matched SLPs or very close to it.1.6 Roller tip Rockers, 305 heads, 355 engine. 24# injectors, stock fuel pump. Under drive pulleys, MSD 6AL box, MSD coil in cap HEI, MSD Wires. SLP runners all port matched at the plenum and some blending to the base. 58mm BBK throttle body, AFPR, and I am sure I am missing something. Yes I gasket matched the throttle body as well.
It ran great, but probably would have unlocked some extra power with a custom PROM... but that was the 90s and... well If we all knew then what we do now. I used the AFPR to get the mixture right. Believe it was lower than 43 we usually see, but I don't remember the actaual number. Probably should have used factory 22lbs.
So I started my build in 2003 my Trans Am is a late model 1986 so it has the flat tappet cam in a roller cam block I have the 305 H.O. 416 heads with the SUM-G5000 they still offer this cam it's called the Sum-1102. I had to stop there because I joined the army in 2005 buy since I retired I've been collecting parts and I'm going to be running the 059 vortec heads I know they're not true vortec heads but they are the best flowing factory 305 head they're a swirl port design I believe and flow 226 cfm at .500 intake and almost 170 at .500 exhaust this paired with my cam and a stealth ram intake for a vortec. My desktop Dyno says I should be at 331 horsepower at the wheels. I also will be porting the heads myself. Also I have a complete world class 5 speed change over kit I've pieced together over the last year together it's cost me $560 for the change over kit a lot of hunting and favors got called in for that I got the trans for 200 so very happy also my car is the WS6 optioned big sway bar full disk brake car so the only upgrade I'm doing is a subframe connection kit maybe Corvette calipers. if you want photos hit me up
Yep I took almost 4.5 mm of casting flash out of this intake I'll be porting my spare as well I also noticed that the upper and runners weren't round so I posted and matched them as well
Opened up the runners to match the upper and lower so it gets better top end and snappy throttle
Depends on how much you are offering I'm always down for sale or trade, right now I'm looking to get a pair of 305 059 vortec heads
Car: 1991 Z28
I just picked up a brand new set of AS&M runners. I got a good condition used plenum I am going to port behind the TB and match up to the plenum, like you have pictured.
If you measure the the inside of the runners I can get it as close as possible for you to mount it on the intake
Car: 1991 Z28
No heads here. IDK $350?... I remember there used to be a guy on e-bay that would port the bases for about $225-$250 and you supplied your own base.
Deal I have a little bit of work to finish on them I should be done by Friday
Do you want the upper, runners and base or just the base
I don't have a set but I'll put a radius so it doesn't hit a hard edge they should be close to the Edelbrock runners
So one of my ported intakes was put on a 305 Z28 1LE 5spees car before the intake it made 238 to the wheels after the ported intake and ported stock throttle body it made 268.9 horsepower to the wheels and 372ft.lbs of torque. If you are from California and are into tpi you know who Dyno Don is he was extremely impressed with my work because I didn't Siamese the upper or lower I made a knife edge between each runner on the upper slightly facing towards the throttle body he said my work was very impressive for not having a flow bench. Sorry I'm just very excited that I could help another 305 guy spank some 350's. Next to Dyno is my ported stealth ram and vortec 520 305 heads I'm running the summit racing G5000 cam and had a custom tune burnt in while in Reno for hot August nights. I can't wait because with my 0-60 and 0-100 times the calculation with my weight is saying that I'm over 300 wheel horsepower but I won't know for sure until I hit the rollers I'll let y'all know soon
305 Stealth Ram with vortec 520 heads
TTOP350 (08-26-2020)
