Plenum Question ?????
Old Sep 1, 2004 | 11:53 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
I have a question. I got a plenum but the guy who had it before me ported the mouth. so much in fact that they compromised the trianglular port that is just below the two holes for the throttle body. Is this Junk ?? Can it be used on a speed/density set up. Mass air? I will try to get a pic to post-Mike
Old Sep 1, 2004 | 12:35 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Shouldn't matter. That's just the IAC port, and all it does is dump into the plenum anyway, so it really shouldn't make much of a difference. At least I think that's the port you're talking about......
Maybe a pic or two would help.
Old Sep 2, 2004 | 12:28 PM
here
Old Sep 2, 2004 | 07:55 PM
TheGreatJ's Avatar
Yah...shouldn't cause a problem.
Old Sep 3, 2004 | 01:14 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You also have a larger TB for that, right? I think I could fit my hand in that! I don't think my stealth ram holes are that big.
Old Sep 3, 2004 | 01:44 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I am currently researching porting such a plenum for my car. There is an article on this website, which discusses how this should be done. The article indicates that the "post" between the two plenum bore holes should not be removed because it would create air turbulence. It looks like this post has been removed from the plenum in your photgraph. Try using this bored out plenum and report your findings on this message board.
Old Sep 6, 2004 | 12:40 PM
Well, Iwasn't going to use it myself. I am probably going to sell it. I just want to know if compromising the IAC port will cause any negative effects. I am pretty sure it wount but i want to make sure.-Mike
Old Sep 8, 2004 | 11:57 AM
cleaned it up a bit...
Old Sep 8, 2004 | 12:23 PM
TheGreatJ's Avatar
Looks like a good plenum to use with a monoblade-converted TB.
Old Sep 23, 2004 | 09:39 AM
So, this can be used with no problems what-so-ever? It wount effect the quality of the idle? Please let me know because I'm putting this up for sale soon. ANYBODY feel free to chime in here.....
MantyZ28
16
Dec 21, 2015 11:02 AM
Thaney9
Aug 29, 2015 03:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
