Converting from Carb to TPI, which year donor should I avoid?
Old Nov 4, 2004 | 08:43 AM
AUGUST's Avatar
Hello,
I planning a swap to TPI on my 350 El Camino, I want to make sure I get the right donor engine. I was told to avoid the 85 as the MAF tends to burn out is this correct? I was also planning on using a MAF system as at a later date I want to add a supercharger to the system and it seems that this would be the easiest way to go or would it be better to go with a speed density unit. Also would an 86-89 year be good for MAF and for SD units 90-92? Thanks for any and all help.
August
Old Nov 4, 2004 | 09:54 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Converting from Carb to TPI, which year donor should I avoid?
Originally posted by AUGUST
Hello,
August
Get an ECM and harness out of a 90-92 '730 setup, and get a HSR. You don't want TPI on your el camino, unless of course you want to go slower.
-- Joe
Old Nov 4, 2004 | 10:23 AM
AUGUST's Avatar
I live in CA. and smog laws only permit me to go to TPI, I can't even go to TBI if I wanted to. Hence the question. What is HSR?
August
Old Nov 4, 2004 | 11:57 AM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
I like the 86-89 types the best. I believe the 85 was a one of a kind and had some problems.
I have an 87 5.7L TPI transplant.
My 87 did not have the VATS (vehicle anti-theft system). No problems with trying to find ways to by-pass the theft system because it didn’t have one.
With a MAF you can change your cam without a need to add a chip to your computer.
I got a “Painless” wire harness #6012 that made the transplant very easly for me.
I love my 5.7L TPI (MAF) system. It’s great for everyday driving, reliable, emissions friendly, good on gas, and goes like hell. Best of all worlds, in my opinion
Old Nov 4, 2004 | 12:06 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
August
You could go TBI.
-- Joe
Old Nov 4, 2004 | 12:19 PM
AUGUST's Avatar
As stated above, smog laws will NOT let me go to TBI only TPI.
Old Nov 4, 2004 | 12:41 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That is not true.
http://www.jagsthatrun.com/Pages/Che..._V-8_Smog.html
Old Nov 4, 2004 | 03:53 PM
AUGUST's Avatar
Thanks for the info, I had been told this info from my mechanic/smog tech, seem's he was told some inproper info.
August
Old Nov 4, 2004 | 07:47 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: TPI
Osh. what kind of cam do you have in your 5.7L? Im doing the same painless wiring Kit Install. ( #60102).
Old Nov 5, 2004 | 09:17 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
1985
Old Nov 5, 2004 | 09:27 PM
vortec77's Avatar
Car: 86 T/A
Originally posted by 91banditt2
1985
Yup hes right, i heard 85's have had problems with the MAF system on that year only.
Old Nov 5, 2004 | 10:24 PM
91banditt2's Avatar
Engine: 5.7 HSR
i say that not because of problems,they (85-92) all have their problems.i say stay away from the 85 system is because of the speed of the ECM.i my self prefer the 90-92 systems.it a much better computer
if your starting with a clean slate i'd go with SD
Old Nov 6, 2004 | 08:40 AM
AUGUST's Avatar
Thanks for the info, I was planning on going with MAF only because I will be adding a supercharger at a later date and did not fully understand about burning chips. Now that the chip burning issue seems a bit more clear to me I will be giong with an SD system.
August
Old Nov 6, 2004 | 01:13 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
If you are going to go SD, then use the 730 or 749 as from the 90-92. You could use either of those while you are still breathing "common" air and then change the code and wiring to run boosted. Get into burning your own chips and you can do anything and be incontrol of the outcome. That's the path I have chosen. Just my opinion.
Old Nov 6, 2004 | 08:09 PM
91banditt2's Avatar
Engine: 5.7 HSR
August
i have heard of people going with a ECM out of a Typhone or a Syclone because they going to run a SC.
Old Nov 6, 2004 | 09:11 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
What is HSR?
HSR = Holley Stealth Ram. Its like a cross between TPI and a tunnel ram.
I had 2 MAFs go out on my '85 Z28. At $200 each that was not too cool.
Old Nov 7, 2004 | 07:20 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The '749 running $58 doesnt control air injection though..
-- Joe
Old Nov 8, 2004 | 08:34 AM
AUGUST's Avatar
Thanks for the info! Does the 730 control Air injection? The typhoon/cyclone option sounds pretty good also (I wonder how hard it will be to find those ECM). Went looking for one yesterday and so far no luck have to keep looking.
August
Old Nov 8, 2004 | 10:14 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
August
The $58, or $60 code will run in a '730.
I could prolly import some of the code frin $8d to get air injection working on $60. infact, i'll put that on my todo list.
-- Joe
Old Nov 8, 2004 | 06:47 PM
JP86SS's Avatar
I'd be willing to help get that imported, I'm getting pretty familiar with the $8D but haven't paid much attn to the emmision stuff. Now I'm studying 58 & 60 and its a bit different from what I see in the $8D. Send me a PM, we can do two prong attack.
Jp
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
