which KN mounts to Throttle Body?
Old Dec 15, 2004 | 12:25 PM
dperk's Avatar
I am looking to get the cone shaped K&N air cleaner that mounts directly to the Throttle body. Does anyone have a part number so I can drive down to Summit and get one?
thanks!
Old Dec 15, 2004 | 04:02 PM
brutalform's Avatar
Check Jegs, there are 2 ...make sure you have S/D
Old Dec 15, 2004 | 04:45 PM
Abubaca's Avatar
What year car do you have?
85-89 use the MAF, and you can't use the cone filter.
90 and up have SD and you're OK.
Old Dec 15, 2004 | 05:42 PM
dperk's Avatar
I have an '86 TPI engine from a corvette and I'm switching it to SD. I live about 25mins from Summit, so I wanted to go pick up a filter for the front of the Throttle Body so I'll be ready to (hopefully) get this engine started soon.
I
Old Dec 15, 2004 | 07:11 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I know from experience that the larger 1000 CFM filter doesn't fit on stock tpi. might work for an LT1, miniram, or stealth ram
Old Dec 15, 2004 | 08:19 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
i bought one a few months ago and i hate it. I think the part # is rc5000 or something close. I actually used the stock intake tube (91lb9) and mounted the KN on the end of it.
Old Dec 15, 2004 | 08:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Right. RC-5000 looks like the largest after my brief look. K&N also makes RU-5004, RC-5004, RC-5010 and RC-5050 for the TPI. You can look them up on the K&N website at www.knfilters.com and maybe the Summit website. Allen
Old Dec 15, 2004 | 11:42 PM
1992rs/ss's Avatar
rc-5050 is the largest and it doesn't fit stock tpi. i know I tried it. plus rc-5050 comes with a bolt sticking out of it for some reason. I am not kidding on this. I have no idea what it is for
Old Dec 16, 2004 | 08:37 AM
dperk's Avatar
The part number for the one Street & Performance sells is "rc-5000". They kept the K&N mfg part number as their part number! I'll probably get the K&N RC-5000 from Summit then. They have it for $42.95.
Old Dec 16, 2004 | 09:05 AM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
i have one of those filters,its used in good condition,you want it?its the 1000 CFM filter ,cost was 50 dollers,have the stuff to put it on a stock tuneport,or aftermarket throtle body.sell it cheap,i just need to clean it first,i used it for about a year.dont know how ide get it to ya ,maybe you can figure that out.im useing the RAM AIR box now,because i have the hood for it.
you have to have a aftermarket hood for this filter,its to big for stock hood ,if you mount it on the throtle body,just thought ide mention that.
Old Dec 16, 2004 | 09:29 AM
dperk's Avatar
what do you want for it? I'll probably take it. Send me an email to my listed address.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
