need a prom chip
Old Jan 9, 2005 | 07:18 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
need a prom chip
Thought i had a problem with the starter doing the click thing w/ no start half of the time so i finally bought a vats ket , the car starts on the first try 90% of the time instead of 20% of the time not to mention sometimes the car will start up and stall out like three times before it will stay running , like its getting enough fuel to start up but then not enough to keep running i am almost sure it has something to do wuth the chip not allowing the injectors to feed the car the fuel.......Who burns the best chips ??? No one in my area knows jack about these cars and so far after $400.00 i am still looking to find a good chip...any suggestions?
Old Jan 9, 2005 | 07:29 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
moates.net, just buy the stuff to burn, a g1 adaptor, and some blanks. then go to town.
Old Jan 9, 2005 | 07:42 PM
Car: 92'Camaro RS
Engine: a loud one
I want to fix the car, not f#$% it up.
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Sounds like you have some other problem, not the chip, you will have to go over all of the basics to diagnose it.
Old Jan 9, 2005 | 07:44 PM
Car: 92'Camaro RS
Engine: a loud one
after diagnosing it 90% sure it's the chip.
Old Jan 9, 2005 | 08:05 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Re: need a prom chip
Maybe the chip is telling the injectors to pulse except the injectors aren't listening (meaning they are not spraying properly). There are many things that cause rough running, stalling and hard starting, GM didn't design the chip with any of those problems. Chips don't just go bad either unless you exposed it to sunlight.
Suppose I burned you a chip and the car had the same problems. Would you complain that my chip must be bad?
Old Jan 9, 2005 | 08:11 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Your problem is not the chip! Start diagnosing systems until you find the culprit.
Old Jan 9, 2005 | 08:45 PM
Car: 92'Camaro RS
Engine: a loud one
okay then...where do i start to diagnose the problem then?
Old Jan 10, 2005 | 08:20 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
First you need to buy a manual for your car preferably Chiltons. Second, pull the trouble codes if your SES light came on and refer back to the manual for troubleshooting procedures for that specific trouble code. I found it kinda funny that you live in Mechanicsburg and no one knows about cars over there
Old Jan 10, 2005 | 08:37 PM
Car: 92'Camaro RS
Engine: a loud one
Okay....no codes...new injectors, new tps, new msd6a ignition box, brand new optima gel battery, new starter , new battery cables.........no one in the area around here knows anything about burning chips or anything regaurdless about 3rd gens, called two speed shops ...no help...they all know stuff about mustangs, one kid they did refer me to didn't have the stuff to burn a chip for the 7165 ECM,again ...no help
Old Jan 10, 2005 | 09:00 PM
mjustdie's Avatar
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
did you adjust your tps correctly? how about check your fuel filter? had that same problem already, couple of bux fixed it up. could even be your fuel pump going bad. did you replace the injectors with the same sized injectors? just some ideas to help, good luck.
Old Jan 10, 2005 | 09:13 PM
Car: 92'Camaro RS
Engine: a loud one
Thanks for trying to help.....injectors are acell 23 lbsW/ Holley AFPR.......fuel pump is an AC Delco just put in about a year ago when i did the swap....TPS is set at .56 V and 4.8 V - WOT.
Old Jan 11, 2005 | 06:14 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: need a prom chip
Yes they do. Memcals go funky all the time. Do random weird things, misread, go into limp, etc.
Reading this, sounds like he checked most everything. There is a few remaining things to check, but I'd try a new memcal now. Or an ECM.
Funny, this sounds much like a Tojan my cousin was working on a few months ago (at an engine shop). Customer came in with the car, said the engine was dead. The shop told the customer the engine was fine, it was the management system. Customer demanded a new engine, shop said "fine your paying for it".
Replaced engine, car still ran rough, idled weird, stalled sometimes.
Mechanics checked everything. Then the called me up. Went down with my memcal adapter and a fresh burned stock chip. Verrified it cured the problem, and had them order a new memcal from GM.
Out the door and a happy customer.
-- Joe
-- Joe
Old Jan 11, 2005 | 06:31 PM
mjustdie's Avatar
sounds like you will need a new "custom" chip. the last time i checked the 350 tpi's ran 21 lb injectors not 23. your dumping more fuel than stock and the ecm thinks its still the same. and accel, well if you look around you will not hear to many good things about accel injectors. what is your fuel pressure set at? turning it up may help a little, but not much.
Old Jan 11, 2005 | 08:48 PM
Car: 92'Camaro RS
Engine: a loud one
Do you mean at idle speed? If so here's the funny thing one time i'll look at it and it'll be at 40 then maybe the next time 45, seems to fluxuate...is this normal??
Old Jan 12, 2005 | 05:20 PM
mjustdie's Avatar
the pressure does alter itself just not at a standing point. your idle and wot settings will be different. did you disconnect your vac line before you set it? it could have something to do with the larger injectors, which would still mean you need a custom chip.
Old Jan 12, 2005 | 07:19 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
An intermittent problem is very very fustrating and very difficult to diagnos (sp).
Also, Memcals going bad is a remote occurance, I doubt very much its the chip.
I have read several scary stories about Accel fuel injectors, these things could be your problem,,, but how to prove it?
What is your fuel pressure? It would be good to hook up a fuel pressure gauge and tape it the the window wiper so that you can see it from the drivers seat.
I would start with the basics,
1) remove & clean the IAC valve,,,
2) remove and check (clean) regap spark plugs,
3) set the static timing to 8* (be sure to disconnect the EST wire when doing this),,,
4) complete the minimum air routine, but set the idle RPM at 650, not the 450 as called for in the procedure,,
5) then reset the TPS voltage at 0.60 to 0.64...
Take care of these basics to start with,,, it will cost you time only
provided that you have the right equipment and tools.
Old Jan 13, 2005 | 04:56 AM
JPrevost's Avatar
Car: 91 Red Sled
Okay....no codes...
Yeah, does the SES light turn on with key on and then go off with engine start? I'm assuming it does since you said no codes, and if you were able to check for codes then you'd have to have a properly working ecm. So if the ecm is working properly then it would also tell you if the memcal was bad. 2 things happen when a memcal is "bad", it'll through a code 52 and blink the SES VERY fast. Strobe light fast and run in backup mode. In the daylight it's sometimes hard to see the SES flickering very fast so look closely.
Sorry I can't help you further but I think we've determined that your ecm and memcal are working properly.
Old Jan 15, 2005 | 12:12 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I would swap out the ECM and memcal liek mentioned before. do the ECM first and if it still has problems put the old ecm back in and get a new memcal.
Also, check all your grounds and power wires.
I am not sure if the problem I had with my stock chip is common, but my stock chip wouldn't turn on my fans. I happened to burn myself a chip when I converted to a manual tranny and the fans started to work.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
dusterbd
Sep 29, 2015 08:40 AM
