Which vacuum line goes to EGR?
Old Mar 18, 2005 | 11:53 PM
Ovrclck350's Avatar
from the EGR solenoid? The top one or the bottom one?
Old Mar 19, 2005 | 11:10 AM
Vader's Avatar
The round one...
There should be a black nylon vacuum line and a gray nylon vacuum line on the EGR vacuum connector. The black line (upper position) connects to the EGR valve pilot.
Old Mar 19, 2005 | 06:56 PM
Ovrclck350's Avatar
Thanks Vader
Old Mar 28, 2005 | 02:35 AM
tyisfly0o0's Avatar
Car: 1988 camaro iroc-z
Engine: L98 5.7 tpi
Transmission: 700 r4
hey the pic u have on there where do both of them lines run too i know 1 runs under the throttle body but i have no i dea where the other one goes
Old Mar 28, 2005 | 11:50 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
to the egr silly
Old Mar 28, 2005 | 03:13 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Is there a way to get the longer one of those 2 tubes mine broke and i have been searching everywhere for one. Is there a part name or something ??? I am desperate
Old Mar 28, 2005 | 05:24 PM
tyisfly0o0's Avatar
Engine: L98 5.7 tpi
mine also broke...so i had to use the soft rubber hose like on the other vacaums...is that bad???
Old Mar 28, 2005 | 05:34 PM
Vader's Avatar
Regular rubber vacuum line should work just fine. You can also get the hard nylon tubing (but maybe not in gray) at many parts stores if you want an original look and lines that last another 15 years.
Old Mar 28, 2005 | 08:10 PM
88cam's Avatar
you can get all the vacuum lines from a dealer bent and everything for real cheap I hear. I personally went with silicone vacuum lines from summit and replaced them all like that it was like a 24 dollar thing and I had to get 2 sets to run it all. I hope that helps alittle.
Old Mar 29, 2005 | 08:15 PM
billyhoss's Avatar
egr delete
if i was to delete my egr valve altogether can i get rid of that whole thing in the pic above? thanx
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TBRays98
Sep 6, 2015 05:05 PM
