Black Cylinder Canister On Drivers Side
Old Apr 3, 2005 | 07:49 PM
klumb15's Avatar
hey guys, what does that black canister on the drivers side in the front of the engine compartment do?? it has like a few vaccum lines running to it, and it has a 2 wire plug on it too.....i talked to a mechanic in my town and he said i can just rip it off...what do i do with all the wires when i rip it off? just trace them back and delete them or what? i was looking at, it kind of looks important for some reason, but he said its just emissions or something.....what the hell is it??
Old Apr 3, 2005 | 08:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, its the charcoal canister and it has to do with emissions I believe. Exactly how it works, I have never checked into it.
A have an '87, thats whats on my drivers side somewhat behind the headlights.
Old Apr 3, 2005 | 08:50 PM
klumb15's Avatar
yup, same place as the battery is on the passenger side....i'm just gonna yank it out then i think....trace the lines and rip them out....i'm on a mission to get rid of every emission unit on the car , thats the only thing left...
Old Apr 4, 2005 | 11:53 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
ITs the charcoal emissions canister and the (2) wires hook up to the purge valve.
(Someone correct me if i am wrong)
There are 4 lines going to your fuel pump.
#1) Pressure line to fuel rails
#2) Vent line to directional vent ending behind back seat (exterior)
#3) Fuel pressure return line from fuel rails
*For you*
#4) The number four line is the vent line going to the charcoal emissions canister. The line runs to the purge valve on top of the canistor. When the computer opens the purge valve it lets the vaccum line from the throttle body pull the vapors from the charcoal canistor.
It rid of mine when deleted the EGR system. You will need to cap one of the vaccum ports on the throttle body and the vent line running to the gas tank. I removed the purge valve off the canister and left it pluged up just so i dont have any problems (ecm) wise, even if there isnt any.
Brian
Old Apr 4, 2005 | 12:27 PM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Re: Black Cylinder Canister On Drivers Side
DUDE- IT'S A BOMB!!!
Just kidding. If you live in an emission test state- DON'T TAKE IT OFF!! It is an evaporator. If you do take it off- DON'T LOSE IT OR BREAK IT!! Unless you like spendimg money on emission parts.
Hope that helps!
Old Apr 4, 2005 | 08:37 PM
klumb15's Avatar
no emissions, i'll never live in a state that has them ...thanks for the awesome info, i'll just trace the lines back and cap them and take care of whatever needs to done...thanks alot guys, i just wanted to make sure nothin really really bad would happen if i took it out...what do i do with the wires? just trace them back and cut them somewhere or what?
Old Apr 5, 2005 | 04:21 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Please dont cut any wires. Just tape them off and stuff them somwhere out of the way.
Old Apr 7, 2005 | 02:18 PM
tyisfly0o0's Avatar
Car: 1988 camaro iroc-z
Engine: L98 5.7 tpi
Transmission: 700 r4
kinnda strange i took mine off last night and i was going to get another one but since i dont have to have 1..even better. but i didnt understand what to do with the vacaum hoses???
Old Apr 7, 2005 | 03:14 PM
klumb15's Avatar
just trace the vacuum lines back and delete them, or if they are spliced into something thats still in use just cap them...then just wrap and stuff the wires somewhere...thats what i'm gonna be doing...
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
