SLP Runners
Old Apr 4, 2005 | 06:36 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
SLP Runners
Yes, I did a search. I got mine a little while ago, and just measured the diameter of the hole. Most guys in the search said theirs turned out to be about 1.4" which is stock. Mine are about 1 5/8" which is about 1.62 or so. Why are mine a larger diameter? I'm not complaining by any means don't get me wrong...I'm just curious.
Old Apr 4, 2005 | 07:55 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Were they used? Newer casting maybe? Different measured areas? That's a vague sort of question without putting it all into context.
Old Apr 4, 2005 | 07:58 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
brand new from SLP purchased about 2 weeks ago.
Old Apr 4, 2005 | 09:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Mine were around 1.59" to 1.60". They varied somewhat. I opened them up to 1.70 inch and made them fully siamesed. Plenty of air flow now. Allen
Old Apr 5, 2005 | 09:00 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
May I ask what you used to open them up to 1.7"? How do you port the center area?
Old Apr 5, 2005 | 10:14 AM
JERRYWHO's Avatar
Just cut them open then weld them back up. I have done some sets and Allen did his.
Link to Allen's set https://www.thirdgen.org/techbb2/sho...hreadid=281400
And a link to my first set https://www.thirdgen.org/techbb2/sho...threadid=46659
Jerry
Old Apr 5, 2005 | 12:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That's not exactly a "DIY" project for those of us not equipped to weld aluminum.
Old Apr 5, 2005 | 12:56 PM
Engine: 3.0
ditto....
Old Apr 5, 2005 | 04:15 PM
Car: 1989 GTA
Engine: 369 TPI
I don't weld aluminum either. I just had the local welding shop do what I needed. I used what are called "sanding drums" to open the ports to 1.70 inches. Allen
Old Apr 5, 2005 | 08:11 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
All the SLP runners are 1 5/8 since that is the stock size of our plenum, runners and base. Even Edelbrocks high flow TPI base part# (I think) 3860 is 1 5/8. I know this because I bought one compared it to my old one and they were exactly the same size. The SLP runners just have no center section so you can stuff a little more air in at the begining. The bottom runner I only ran a ball hone thru to clean up the casting a little the top is fully ported I am still polishing as we speak.
Attached Thumbnails SLP Runners-c-documents-settings-preston
Old Apr 5, 2005 | 09:09 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
were do you get a ball hone?
Old Apr 5, 2005 | 10:35 PM
Car: 85 87 87 91 92
I called around to some of the local machine shop "Supply" companies. this is a worn out one but it started out as a 3 inch ball hone and after craming it down the runners a few times the bristles shaped so it wasn't that big any more then as the stones wear down it gets even smaller but still works well.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
