super ram install tips
Old Apr 11, 2005 | 08:54 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
what are the torque specs for the plenum lid bolts, the plenum runner bolts and the runner manifold bolts?
-also, is there a way to download the SR install directions anywhere? well...i guess all i really need is the bolt specs.
-also, I tried to take off my plenum lid, but after i took the bolts out, it was stuck. What do you think the best way to do this is...thanks?
Old Apr 11, 2005 | 10:56 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Lingenfelter.com has directions to download.
Your lid has probably been RTV'd. You will need to pry it up a little. Careful not to chew up the aluminum.
HUGE tip. Bore out the 4 center holes in the plenum and use a bolt/nut instead. As for the other Plenum bolts, take your dremmel tool with cut-off wheel and cut a slit in the end of the bolts. Then you can use a screwdriver to run them up from the top. You should re-tap the plenum holes as well, this will allow the bolts to run up easier.
These tricks will make a six hour job a 1 hour job.
I have had my Superram off about 4 times.
Old Apr 11, 2005 | 11:01 AM
Car: 1987 GTA
yeah, i tried, but i feel like i'm gonna break it or gauge it....thanks for the other tips. torque specs? th8e page for the instructions was removed, can i get them anywhere else? thanks
Old Apr 11, 2005 | 11:11 AM
Car: 1987 Iroc-z
Someone else has a huge thread concerning this. Check it out. It details what I said plus some more stuff.
As for torq speqs, I don't think the directions ever had them. I hand tightened everything.
Make sure you gasket match as well. The EGR tube presents a big vacuum leak because the gasket holes are to big.
Old Apr 11, 2005 | 11:28 AM
Car: 1987 GTA
what do you mean about the EGR? thanks man.
Old Apr 11, 2005 | 11:41 AM
Car: 1987 Iroc-z
If you look at the small port in your runner. It resides on the passenger rear ports if you can imagine it installed. It's a small port molded next to the 2 big runners (cylinder 8 & 6 Ithink). That small port is used for the EGR. That hole in the gasket is way to big and it presents a vacuum leak so bad that you can see it at the top of the gasket. This is the runner to the manifold connection. I went as far as getting some gasket paper and making my own (exacto blade and dremmel tool). Made the hole the right size.
Old Apr 11, 2005 | 01:46 PM
Car: 1987 GTA
does it always leak? any other solutions? little RTV?
Old Apr 11, 2005 | 01:50 PM
Car: 1987 Iroc-z
Ya, That will do I guess - just identify the problem and work with it. Build the manifold and runners on the bench and gasket match everything. I had to take my dremmel tool with sanding wheel and notch the gasket bolt holes to match the ports better and make a better seal. They sit crooked out of the box (factory stamping sucks). Nothing is true bolt on, EVERYTHING is custom.
Old Apr 11, 2005 | 01:54 PM
Car: 1987 GTA
Old Apr 18, 2005 | 12:08 PM
psidy's Avatar
Did you get the lid off? Here's an idea. Find a piece of wood or something similar and stick it through one of the runner openings and gently hit the bottom of the lid with the piece of wood and a hammer. That's what I would do anyway.
Old Apr 19, 2005 | 09:13 AM
Car: 1987 GTA
yeah, i got it,. I'm up to the blower and headers already, the accessories and cooling system are on.
rocn7roc
Sep 21, 2021 02:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
fonzie85
Aug 13, 2015 11:50 AM
bryan623
Aug 10, 2015 11:33 AM
