How hard is it to get a 383 to pass emissons?
Old Apr 26, 2005 | 03:06 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Ive been looking at doing a 383. Will it be able to pass the smiffer with a stock 350 chip? Or am I better off building a 350?
I havnt picked out a cam yet If somone know if a good one that will pass emissions and work well with the tpi that would be great.
The rotating assembly im thinking about going with is an eagle cast crank, 6 inch forged i beam rods, and forged j and e pistons. The CR with 64 cc heads will be 9.8 to 1.
Not sure on the heads was going to do afr but the jegs guy said they are 3 months behind.
Old Apr 26, 2005 | 06:52 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: How hard is it to get a 383 to pass emissons?
Originally posted by 91RS5speed.Ive been looking at doing a 383. Will it be able to pass the smiffer with a stock 350 chip? Or am I better off building a 350?
With Speed Density? No. You'll need to tune the chip. Once tuned, you should pass with flying colors. People over here are easily passing New Jersey inspection without even runnin EGR's, all through tuning. Just take it easy on you're cam selection...
Off topic: You have a very clean Camaro there, and you're TPI transition looked to go very smooth. Excellent job. About those Dominion heads though, were they your's? If so, WHY did you sell them?
383 + Dominion Heads + HSR = DEATH!!!!
Old Apr 26, 2005 | 11:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
On my 383 LPE219 SR and TF heads I passed with just a Cat. No smog or egr.
Old Apr 27, 2005 | 09:39 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There is a guy around here that passed with a 383 LT1 with a GM 847 cam (232/242 I think).
Old Apr 27, 2005 | 02:01 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
My Super Rammed 383 passes NJ Inspection with a custom chip cleaner than the day the car was new.
Street_Lethal are you on njfboa.org yet? If not check it out.
Old Apr 27, 2005 | 02:11 PM
I just joined.
Old Apr 27, 2005 | 02:26 PM
91RS5speed's Avatar
Car: 91 RS
The Dominion heads were a friend of mine they were for an lt1. He desided it was to much work to get custom headers and intake to make them work for his car so he sold them off. I thought they looked cool so I left them up on the sight for people to see.
How bad will the 383 run on the 350 chip? If its not going to run I might be better of doing a 350 that way i dont have to fight with a tune.
Old Apr 27, 2005 | 02:33 PM
Car: 89 IROC-Z
Engine: 383
Build the 383 and get a chip.....the low cost of a chip justifies the increased displacement trust me.
StreetLethal.....FYI my name on njfboa is HardcoreZ28
Old Apr 27, 2005 | 11:33 PM
camarocruzin's Avatar
Car: '89 Iroc
Transmission: 700-r4
sorry to tap into this thread but when doing a 383, or a 400 swap will the car at least START on the stock chip? idle like ****, and fall on it's face is fine, but would it start??
Josh
Old Apr 28, 2005 | 07:56 AM
Car: 89 IROC-Z
Engine: 383
I'm not a complete expert but I'd say if it's a MAF car it should start and just run bad. SD might have some issues staying running or starting at all.
Old Apr 28, 2005 | 11:16 AM
91RS5speed's Avatar
Car: 91 RS
Were do u recomend getting a chip from? I have 24 pound lt1 injectors that had just come back from the cleaners will thoughs work ok?
Old Apr 28, 2005 | 12:03 PM
Tibo's Avatar
Car: 1991 Z28 Vert
That is a nasty issue. Once and a while a guy on these boards might burn you a chip to get you started, for a small fee. What usually happens though is that you will end up paying some guy around $100 for the first chip, then every chip after that is "X" amount. A lot of chip guys who do chips won't even touch an engine that has been modded quite a bit. IE a 383 with ___ and ___. So the best bet is to start learning now on what engine you have.
Old Apr 28, 2005 | 12:36 PM
Car: 89 IROC-Z
Engine: 383
I don't know if LT1 injectors fit our wiring harnesses, somebody else might know. As far as chips....if you're going to go mail order then I think PCMForLess is supposed to be pretty good. After that I'd find someone near you to do a better tune in person if you want any tweeks and such.
Old Apr 28, 2005 | 10:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
LT1 and LS1 injectors fit our harness' fine, trust me, I have run both.
Old Apr 28, 2005 | 10:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
If you have a Maf and stock injectors any size cubic inch motor will start right up and run fine considering the timing is stock and also valves are adjusted right. Once you mess with injectors then you need a chip. If you get 30lbs injectors and have a chip burned to stock specs but the constant at 30 the car will run fine.
Old Apr 29, 2005 | 02:04 PM
roarin_mouse's Avatar
Car: Z-28
Engine: 383 stroker
Probably the biggest factor in building a narrow band O2 engine that will pass emissions is your cam selection. This is especially true if you also have headers. Headers increase scavenging and so does a cam with a tight LSA. The problem is that too much scavenging, while great for horsepower, results in an overly rich mixture when in closed loop. The sniffer tests are done at low power settings when your engine is in closed loop.
The rich mixture is because of the following:
Scavenging draws air into the intake during the exhaust/intake overlap period. Unfortunately, some of the intake air is also drawn into the exhaust when this happens. The fresh air in the exhaust presents itself to the O2 sensor as a lean mixture (because there's too much unburned oxygen). The ECM increases the fuel flow until the 'apparent' mixture is again 14.7:1. In effect, the engine is now running too rich but the ECM thinks everything is fine.
Use a cam with no less than 114 degrees of lobe seperation or change your system to a fulltime wideband (costly). Unfortunately you can't make tons of horsepower, have great fuel economy, and pass emissions testing with a narrow band O2 system.
Old Apr 29, 2005 | 03:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
dont stick with a 114. Its possible to go lower then that. Heck. Mines 112 and passes with flying colors and also the 85 305 TPI'S came with something like 110 or 109
Old May 1, 2005 | 01:53 PM
Tibo's Avatar
Car: 1991 Z28 Vert
You read my mind. I believe that Capt. Picards Z28 has a 110 or 108 and is said to run very good on it.
Breazlan
Sep 25, 2015 11:20 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
abray1
Sep 10, 2015 04:53 PM
Randomtask2
Sep 7, 2015 05:06 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
