TPI runner leaking fuel ??
Old May 17, 2005 | 04:25 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Project "replacing TPI seals/gasket" by GTA89 ! Need also your support !
Old May 17, 2005 | 07:51 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Sounds like you might what to see if it's Fuel,Oil or coolant leak first. If it's oil and or coolant you need the upper and lower intake gaskets. Those lower intakes leak it's pretty comman. Just don't use the cork gaskets on the china walls (when going back togther) trash those if you deside to do it your self use RTV gray sealer on the china walls don't be shy eirther use a fair amount kinda like your welding nice fat weld. It might be leak injectors and fuel rail most likey is an intake leak though. If you've never slapped a lower intake on any kind of car then don't get your self stuck take it to a pro. Otherwise it's kinda a gravey job after you do it a couple times. Tools that you need are not rare too, so finding tools might be easy.
I took my intake apart 3.0 hours with air tools and years of auto technlogy expreance. I'm porting my intake too it was leaking so i'm doing all kinds of small free bees while in there. Like porting, fuel regulator, injector o rings, distrubtor replacement.
Old May 17, 2005 | 08:04 PM
GTA89's Avatar
Engine: 5.7 350
Old May 18, 2005 | 08:05 AM
8UpAFord's Avatar
Car: 1988 Corvette
Sounds like you might have a intake leak? When you say fuel do mean gas. If so does it small like gas. I think you have an intake leak. Unless somehow your throttle body is leaking cooling into the peluim which will cause the coolant to seep out the runners I guess. you might just wanta have your local shop take a peak at it with you. Normally shops out here don't charge unless you want the job done. You might just have sepage which you might be able to get some more miles with out replacing gaskets.
Good Luck
Old May 18, 2005 | 08:13 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Gas visibly leaking out of your runners probably is your fpr leaking and getting sucked into the plenum.
Coolant on the side (typically the front drivers side) is something that happens often, you need to replace the intake gasket.
hth.
Old May 18, 2005 | 09:33 AM
GTA89's Avatar
Engine: 5.7 350
Old May 18, 2005 | 10:26 AM
8UpAFord's Avatar
Car: 1988 Corvette
Red Devil good call. Forgot about the regulators taking a dump and fuel being sucked into the pleuim that way.
well good luck with the project
Old May 19, 2005 | 09:26 AM
GTA89's Avatar
Engine: 5.7 350
NEED HELP ASAP
Old May 19, 2005 | 09:39 AM
8UpAFord's Avatar
Car: 1988 Corvette
You gotta make sure that you get all the bolts. I think there are 6 at the bottum and top. But it's tricky you'll need to pull both runners off. inside of the base theres bolts too make sure you find those. you can down load a manual on how to remove a TPI, im sure theres gotta be somthing out there. There kinda a pain in the butt the first time. Once you get the bolt it's doent take much to pull them off they should break losse. if your pulling hard and nothing is coming loose you need to find all the bolts.
Old May 19, 2005 | 09:42 AM
GTA89's Avatar
Engine: 5.7 350
Old May 19, 2005 | 01:21 PM
GTA89's Avatar
Engine: 5.7 350
Old May 19, 2005 | 02:30 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Turn the black one, use the white one to turn off of. (White stays still.)
Old May 19, 2005 | 02:59 PM
GTA89's Avatar
Engine: 5.7 350
Old May 19, 2005 | 10:56 PM
GTA89's Avatar
Engine: 5.7 350
Re: !
Old May 20, 2005 | 09:14 AM
8UpAFord's Avatar
Car: 1988 Corvette
Damn dude, You must have a lotta time on your hands you have a ton of good pictures too. You should be able to pop that sucker off. pull and twist a little then she should pull up out there.
Old May 20, 2005 | 09:30 AM
GTA89's Avatar
Engine: 5.7 350
Thanks for your reply !
Stay tuned, while i updated the pictures again...
Old May 20, 2005 | 10:13 AM
GTA89's Avatar
Engine: 5.7 350
Old May 20, 2005 | 10:25 AM
8UpAFord's Avatar
Car: 1988 Corvette
Wow looks like you pretty much got a compelete kit. The round seal is rear main seal you need to pull the trans out for that and yes you have bonus kit the head gaskets. Do you plain on replacing the head gaskets? I think you where only trying to replace intake right? if so just keep track of the old gaskets and replace with the new. To clean inside get some degreaser and maybe a brush and water/ soap and clean. oh get some brakekeeln that works good
Old May 20, 2005 | 10:28 AM
GTA89's Avatar
Engine: 5.7 350
Project "replacing TPI seals/gasket" started by GTA89, need you help too :-)
Old May 20, 2005 | 10:33 AM
GTA89's Avatar
Engine: 5.7 350
Old May 20, 2005 | 01:23 PM
8UpAFord's Avatar
Car: 1988 Corvette
Yeah make sure you order lower intake gaskets that mate with the heads. To clean your parts i would use a tyipcal degreaser wire brush on the inside and the outside if you want it to be show car stlye you'll have to do a seach on this website for it. Power coating in the best longest lasting way but costs$$$. I was thinking about doing somthing like that to mine but i like the stock plain look better as long as it's clean. takes a nice amount of time sandying and cleaning **** like that. i invested most of my time porting out my TPI unit. I rather go for preformance over looks. but thats just me.
Old May 20, 2005 | 01:30 PM
GTA89's Avatar
Engine: 5.7 350
Old May 20, 2005 | 01:37 PM
8UpAFord's Avatar
Car: 1988 Corvette
No sorry don't have any idea? So you live next to Amsterdam? Lotta the good stuff rolls around that way haha.
Old May 20, 2005 | 02:09 PM
GTA89's Avatar
Engine: 5.7 350
Old May 20, 2005 | 03:18 PM
8UpAFord's Avatar
Car: 1988 Corvette
yeah thats where all the green stuff is right, hahaha
Old May 20, 2005 | 03:25 PM
GTA89's Avatar
Engine: 5.7 350
Old May 20, 2005 | 05:41 PM
8UpAFord's Avatar
Car: 1988 Corvette
hahah good times.... Hey let me know if you need anymore help i'll try posting quick
apie2546
May 23, 2015 07:49 PM
TkernIROC1986
Apr 18, 2013 07:08 AM
jamez74
Nov 21, 2007 09:21 PM
RaysIrocZ88
Apr 9, 2003 06:23 AM
Gambit69
Jan 12, 2003 06:53 AM
