108 octane gas, OK?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
108 octane gas, OK?
I have a chance to get some 108 octane gas for 2.25 a gallon and it come in 55 gallon drums. Guy says the color of the gas is blueish.
With gas prices now that would be the same.
Should I get it? and will it harm my engine? I guess I could mix it half and half?
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Well at that price I would buy as much as possible, that is cheaper the low grade here in NY is.
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
In Ottawa, Ontario, Canada I am paying:
$0.93 Canadian per Liter
1 Gallon = 4 Liters
$0.93 Canadian = $0.74 USA Using exchange of 0.792011
So, 1 gallon in Ottawa, Canada is 4 x $0.74 = $2.96
Edit - This is HiTest...
1 Gallon = 4 Liters
but will it harm my sensors in any way? is 108 leaded or unleaded?
Engine: 388 Carb
Axle/Gears: 4.10
I am pretty sure that it can be either or and if it is leaded it would ruin the cat. converter. Just make sure before you buy it.
I dont have a CAT on my car.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
You should be fine than. The only thing lead can hurt is the carb. In fact, air planes have lead in their fule to prolong engine life (or something like that, I forgot exactly why).
Again, you wont see any gains by using such a high octane, but if it's cheaper than local gas I dont see why you shouldn't buy it.
lead was in fuel to cushion valve seats and guides. the higher the octane the slower the fuel burns. if you are not pinging now you dont need it. the lead will plug your converter. if you still buy it bump your static timing up to try and get some gain
is 108 usually leaded or unleaded? do they even still make leaded gas?
When I fill up I spend about $30.00 and that for just about 15 gallons.
So if I can get the 55 gallon drum of 108 for $123.75 ....that seems like I good price even if I just mix it 1/2 & 1/2
Engine: 388 Carb
Axle/Gears: 4.10
Heres an article I found online. [QUOTE][QUOTE] Unocal’s 76 Racing Gasoline offers two different types of racing gas: 108-octane leaded and 100-octane unleaded. The 100-octane unleaded is oxygenated and therefore legal for use in street-driven vehicles. Often, 100 may be more octane than you really need for your engine. You can mix the 100-unleaded with 92-octane pump gas to create the octane you need to eliminate detonation. Yes they still make leaded gas but it is fairly expensive and is not easily found. Either way it is a really good price, why dont you just ask the person you are buying it from if it is leaded or not?
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i believe 108 is leaded
that is a great price
you can mix 3 gal of 87 and 1 gal 108 and come out at 92
good way to save some $$
but
i believe the O2 sensor might freak out
the higest unleaded i have seen is 104 from sunnoco
they also make GT100 unleaded too.
the cat. convertor doesn't like leaded gas either
but
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I have ran 110 here in memphis quit a few times because my buddys dad has surplus for his race cars and there was times when we didnt have the money for gas. This was a few years ago when my car was bone stock and i never had a problem. He ran it thourgh his vortec silverado and never had a problem.
Like iroc&harley said bump up your timing and take advantage of it.
I'll ask the guy tomorrow and see if its leaded or unleaded. If it unleaded Im jumpin on it! Cause right now I do get some pinging at WOT....and I just have my timing set at 8*
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Do you really want to deal with filling your car up with a 55 gallon drum when you need gas? Seems like a hassle to save a few cents a gallon.
its all about the 108 octane.
oh well, I just asked the guy and he says its leaded 108......
