Oil pressure dropping when braking
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I've noticed that my oil pressure drops sometimes to 0 during hard braking. I don't know if my gauge is being stupid, or I really don't know. Cuz I've never seen that happend even with my stock motor. I do have a stock oil pan with no windage tray, but I wouldn't think I would drop to 0 psi when I brake hard, even medium braking does it. Engine don't make any noise or act different, just my gauge reads the pressure drop. Any ideas would be appreciated.
Tyler
Tyler
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I'm NOT trying to ba a smart a$$, but haave U checked the oil level?
How much pressure does it normally have at idle + at speed after oil is warmed up?
My wife's car (87 RS--V-6)--did that until I replaces the oil pressure sending unit--might want to try replacing that.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Originally posted by RBob
Pickup fell off the oil pump.
RBob.
RBob.
Engine: 5.8L 355
No the oil level is just fine and dandy. I changed it today. And the pick up should be fine. I have about 30-35 psi at idle, and I run somewheres around 50-55 at cruse speed. Just when i brake it goes way down. I thought about the pick up tube also. And my sensor is right above the oil filter on the side of the block.
Tyler
Tyler
Engine: 5.8L 355
Oil pressure is good all the time, but when I come to a stop it drops down. Like I said oil level is fine, no clattering, nothing. Just the gauge reads low psi when I come to a stop. Drops way fast when braking hard.
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
my car did the same thing. it was fine until i hit the brakes. the pressure was the same as yours too when not braking. it was just that sensor.
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
Mine is doing the same thing and wont really hit over 35 either. I did just go from 5W-30 to 10W-30. So I might switch back.
Engine: 5.8L 355
yeah I was thinking, that it shouldn't be starving from oil. You would think it would make noise. I know I'm full on oil. And my sensor is new, but that doesn't mean its any good. I'll prolly try changing it and see what happens. I highly doubt my pickup tube fell out. You would think there would be no pressure at all.
Engine: 5.8L 355
Transmission: 4L80E/4L80E
Mine was doing the same exact thing. It's been doing it for over a year. At first I thought it only did it when it was less than 1/2 quart below full, but the last quart I added brought it up to full and it definately was still doing it. I also recently changed the oil pressure sender, no difference.
I pulled the engine this past weekend in prep for the 350 shortblock project. When I pulled the pan, much to my dismay I saw the pickup had divorced itself from the pump. I found I could not get it to stay by simply trying to drive it into the pump. This was a ZZ4 take-off pan, pump, & stud-mounted baffle from SDPC back in '01. Basically brand new parts (why the pump and pickup were separated I have no idea).
So, now my question: Is hardening Permatex #1 adequate for a lasting marriage? It'll have plenty of time to set up before being installed. Or, should I just bite the bullet and borrow the co-worker's flux core wire welder and weld the two together? I don't have access to brazing equipment (although I could probably get out the carbon arc equipment for my old Lincoln stick welder and give that a try).
Car: 1988 IROC-Z
to be on the safe side just tack it. don't start running beads, the heat might distort the pump body.
2 small spot welds are plenty good for holding the pickup to the pump.
You would think that with as much force as it takes to drive a pickup home into the pump that it would never come out again. But they do, and with frightening regularity. I never assemble my engines until I tack weld the pickup to the pump, or use a pickup that bolts to one of the oil pump corner bolts.
To my eternal shame, this one did not drive in hard. I should have known it wasn't going to stay in.
