My 305 TPI is running like crap! :(
Old May 22, 2005 | 09:24 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello all, I have a 1988 Pontiac Trans Am GTA with a 305 TPI, all original with no modifications at all... Automatic transmission, 3.27 rear, all options except leather and the 350 TPI.
The problem is, when I give my car 1/2 to 3/4 of of the throttle, it shakes, like it doesn't have all the power... When I put the pedal to the floor, it shakes too, and become good after 1-3 seconds of flooring it... Sometimes when I keep it stomped for like 10 sec, it do it for 1-3 sec, became normal, beging to shake a again, normal.......
Old May 22, 2005 | 03:58 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I need help... Please!
Old May 22, 2005 | 08:28 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Could it be in the tranny?
Just a thought.
IF its definitely in the motor what about the cat being stopped up?
Old May 22, 2005 | 08:39 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
The tranny as been rebuild less than 15 000 miles ago... And it was shaking sometime when I was just stopped at a light. I don't have a cat anymore.
Old May 23, 2005 | 08:57 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
So I hope I find the problem fast, my car was supposed to be on a dyno tomorow the 24!
Old May 23, 2005 | 01:49 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
What about the MAF sensor? I remember my car sputtered at idle and low mph, but it was more like a bogging down feeling. Did you recently move the intake? Maybe it's disconnected.
Old May 23, 2005 | 06:30 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I took the GTA out today again... The problem is still there but less than the other time.
When I'm at a stop light, sometimes it do a little shake here and there, is it a miss? When I remove the foot from the brake and push the gas pedal, it shakes while accelerating. When I put it to the floor, sometimes it go like normal, sometimes it shakes a little and accelerate not as fast, became normal again, slow, fast, slow.......
What do you guys think it could be beside a bad fuel filter?
Old May 23, 2005 | 07:47 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I decided to change the fuel filter tomorow... I'm looking at ACDelco Canada's web site and it come up with a GF652 filter ans a GF481C. What is the difference between the 2? On the US site I get only the GF652...
Thanks!
Old May 23, 2005 | 09:45 PM
Plugs, wires,Cap, Rotor all good?
Maybe a plug wire got into the manifolds (or headers).
Or the wires may be breaking down.
Old May 24, 2005 | 01:21 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
what kind of shake is it??? are the rpm's fluctuating when it shakes? or staying steady?? give us more info please!
Old May 24, 2005 | 07:18 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
It seem to stay pretty much steady... It doesn't go down, but when I floor it, it doesn't go up as fast as normal!
Old May 24, 2005 | 09:33 AM
Another guess:
Harmonic balancer came apart?
That would cause a shake.
The rubber ring breaks down over time.
The outer ring slipps off. Usually makes some noise though.
Hard to guess not being there.
Old May 24, 2005 | 10:33 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
This happend to me 2 years ago. Disconnect your battery for 15 minutes then connect. Lemme know if it still runs like that
Vintageracer
Jan 10, 2020 05:33 PM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
